Help! Debris found in my engine - 610/630 clutch issues
Discussion in '610/630' started by Rough Rider, Feb 9, 2011.
  1. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    tap tap tap... :)
    The secret to it is backing the head, and being good enough with a hammer to have the tip of the ballpeen hit where you want it to. It's more like hammering than tapping. Wifey came out to the shop to see what the hell was going on.
    Some of the guys have used an airhammer. Anyway, the idea is that you beat down and roll over the end 'till it cinches up tight. It's more of a feel. Once you get it you got it...really pretty easy. Steel is definitely a lot tougher than brass or bronze. I once built a clinker planked skiff that had the plank lands riveted together with copper rivets. On that you could hear when they were getting tight.
  2. RDTCU Husqvarna
    '11 630SMS
    I normally use a ball-nosed punch and a 2lb hammer for steel rivets around this size.
  3. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    I am happy that I just ordered the Indy upgraded spring cup washers. My 630 is pushing 10k miles. I will be ordering the bronze bushing from MotoXotica for good measure. I plan to take pics of what I find. I have not ridden it as hard as I have my 510, but it has been ridden hard. The 630 is such a good bike I want to keep it around as long as I can. I don't think there is a better DS bike available, and yes I have rode an orange 690 off road. :cheers:
    Kenneth Webb likes this.
  4. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Just replaced the clutch actuator arm on my one 610TE than now has just over 42,000 km on ----checked the springs and washers --still in great condition ????
    Think I have been lucky with this bike never a days issue -- but must say I drop the engine oil every 2,500 km's sometimes 1,000km depending on the riding I have been doing. and do the oil filter every 5,000km
  5. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    Just make sure none of the little spring cup washers aren't getting thin. I haven't heard of any that weren't. If they get too thin they come apart and go into your motor. Not pretty. For the $85 to do them it's worth it for prevention.
    I put it off and off and off...finally did it and it was way easier than I thought it would be and way worth it. The Indy washers look 'indy-car' grade compared to what came out of there. (see what I just did there. :D )
    Blazes likes this.
  6. Blazes Husqvarna
    South Africa
    Luckily I have a new complete clutch unit hub and all that I got a few years ago --so when the day comes I will pull it--fit the new one and re-build the old one as a spare :)
  7. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    This is what mine looked like at 9,7xx miles. washers were thin and worn. You can see that the springs were banging around by the chew marks on the gear side of the hub. I am glad I got it fixed with the Indy spring cup washers. I took the clutch to a local shop and he drilled out the rivets and reassembled with a 20 ton press. I tapped the spring inward towards the clutch housing/away from the gear plate before reassembly in the bike. I am happy with the results. I have another set of Indy washers on hand for the other 630 fix I have to do.
  8. Stujam Husqvarna
    Brisbane Austrlia
    09te610, 11te630
    Where does everyone get there rivets , are they a husky specific size only available from dealers - last time i rivets sent from halls usa to oz but exchsnge rate was better then ..
  9. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    The rivets I used were included with the Indy Unlimited spring cup washer kits.
  10. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I got the rivets from Halls as well.
  11. KLOC Husqvarna
    Edmonton, Alberta
    Just heard from Indy Unlimited regarding the cup washers:
    "Sorry no longer have any available. No plans to make another batch of 10,000."
  12. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Times and people change. He helped a lot of peeps though.
    The real fix is a cush hub though.
  13. FasYankee Husqvarna
    Where you'd least expect
    BOOM!
    Well WTF now? I just spent all this time reading this thread after getting referred here from my wonky clutch engagement thread. I was all set to just order this kit and get started on it in the fall/winter. Assuming that mine are at least partially worn bringing them to my machinist to reproduce would be asinine. Does anyone know the true dimensions of these washers/have a diagram? I love riding this bike but honestly I'm pretty close to going back to the *just put gas in it and change the oil* Japanese route. Damn thing is almost as high maintenance as my wife
    Flynn likes this.
  14. kirbybikes Husqvarna
  15. KLOC Husqvarna
    Edmonton, Alberta
    Spice Weasel quoted these dimension for the spring cup washers:
    scudster likes this.
  16. Stujam Husqvarna
    Brisbane Austrlia
    09te610, 11te630
    Jap sgls , katos -- they all have week points somewhere that need attention. .once you sort these issues you should be sweet .. My mates that maintain their bike dont have dramas - my mates that are crap at maintenance have dramas . I have done a fair bit of saddle time in 610 and now 630 and i have never been left stranded .
    Pull your clutch out and check the washers ( they may need changing or may be ok for a while ) but i reckon what you describe is likely more the bushing the hub sits on is worn , creating slop and hence rough engagement .
    Your issue should hopefully be easily and cheaply fixed ..
  17. mjskier Husqvarna
    Northern Colorado
    2011 TE 630
    2012 KTM 990 SMT
    So no hitting the rivets with a hammer, he just put them in the press and that was good enough to squish/expand them?
  18. mjskier Husqvarna
    Northern Colorado
    2011 TE 630
    2012 KTM 990 SMT
    Old vs. New (Indy unlimited kit)
    Dimensions:
  19. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    The factory installed rivets looked pressed to me, nice and uniform. A 20 ton press will do a better job then I ever would with a hammer. I will be doing the same on the next basket.
  20. mjskier Husqvarna
    Northern Colorado
    2011 TE 630
    2012 KTM 990 SMT
    Are the clutch spring bolt really only tightened to 5 N.m?
    That feels like barely compressing the springs! Doesn't show any locktite, so I assume the spring tension is enough to prevent them from backing out?
