Help! Debris found in my engine - 610/630 clutch issues
Discussion in '610/630' started by Rough Rider, Feb 9, 2011.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    Thinking back, my 99 te610e dual sport locked up in gear the first time I rode it. The arc in the shifter drum cam that guides the ratchet in the drum was wrong. Once the arc was opened up it shifted ok. Food for future thought.
  2. motranqui Husqvarna
    Madrid (Spain)
    TE310 2010 & TE630 2010
    Yamaha YZ 250 F
    It's OK, it's Ok,I apprecitate your advices :)
    I'll try to contact with a lathe operator (I don't know if it is the way to call a man that makes iron pieces) and I'll ask him how much can it cost to make the improved washers
  3. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    Look back to post #296 in this very thread.
    motranqui likes this.
  4. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    BTW, I've uploaded this video. I hope it helps somebody :)
  5. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    BTW, it sems to have consensus regarding to the dimension of the upgraded washers. What about the kind of steel? A "hardened one", I have heard. Could anyone be more accurate, just in case I order them to my local lathe operator? I guess, order only 12 units will be quite expensive and finally I'll contact the guy from SudhAfrica... but I want to make a try
    Thanks
  6. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Pics of my washers. Make sense that they have some notches... 23.000 km having to stand a lot of stress among springs, iron and aluminium pieces... One of them is a new one.
    I've compared the old rivets with the new ones (I ordered them months ago) and the head doesn't look equal. What do you think?
  7. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Hi
    Brainstorming :thinking:
    I took these mesurements.
    The gap between iron and aluminum part is 6 mm (3 for each side). Springs can be compressed up to 5mm, which is OK. If we make the whashers 1mm thicker each, it's like we preload the springs 2mm. That means that the theoric free play (clearance) between pieces goes from 5mm to 3mm, which is 40% less, that is, 40% less "cush hub" efect.
    If you grab a spring with a pliers and try to reduce its lengh 2mm, you'll see that costs quite a lot. And it's only one spring. To reduce it's lenght a little more cost you an arm.
    So, upgraded washers implies less free play (less cush hub efffect) and a lot more of preload in the mechanisim. So I wonder why the upgraded pieces were not made of a better treated iron, but keeping their original measurement so that the characteristics and performance of the mechanism were kept.
    I've hamered one of the old washers grabing it with a vice and it has not broken even bending it up to 45º several times. Also I pressed it with the vice a lot and almost has keep it's shape.
    Don't get me wrong, I do not want to be the smartass of the party... only wanted to share this thoughts with you
    Theo likes this.
  8. Spice Weasel Husqvarna
    UK
    08 SM610
    The higher the carbon content of steel the higher the hardness, resistance to abrasion and deformation. and vice versa the lower the carbon content.
    Youve just proven the low carbon content of the steel that the OEM washers are made from, probablys mild steel, and how unsuitable they are for their purpose. Even EN8 would have been more suitable. This is why we are getting replacements made from tool steel.
    You will not like the ones i had made with 3mm thick bases, but i have done 7500 miles with them in my clutch, all on paved roads, and not had any problems. :cool: My OEM washers were in pieces in my sump by 5000 miles
  9. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Yes, I agree with you: something has to be done because the worst excenario is a broken engine
    But I think that after 23.000 km my cup washers looks almost like new ones, so it proves that not all the washers had the same quality. But quality has not necessarily to do only with thickness. That's why I was wondering why every one doubled their original dimension.
    If the original ones, made of a "mediocre" steel -as you say- can stand 23.000 km (or more), How much could stand if they were made of a better iron quality?
    I mean, if we had increased them by, let's say, a 25% (what is a lot in enginering process), with a good hardened steel, we would have a 1,25 mm thickness "superb quality washers" which would have only decreased the hub cush effect up to a 10%
    That's why I think: Should be increased the quality of the washers? Yes, without a doubt, because you never now if you have a good ones (like the ones in my bike) or a bad ones (like some that were broken with only 7.000 km). But, so... Should we increase their thickness. I don't think so, at least not to the double.
    Spice Weasel likes this.
  10. Spice Weasel Husqvarna
    UK
    08 SM610
    @motranqui I can not fault your reasoning, you make a valid point.
  11. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Today I took the clutch to a lathe operator so that he put the rivets
    He spent a lot of time (half an hour :eek:) an finally he brings the clutch like this:
    It's obvios that he has not made the work properly :mad:
    When I came home, I remove the rivets again (very easy work now) and, guess what I've found:
    So, he has broken the clutch housing an also he has bended the metal cap that prevent the springs from coming out
    So, a 500€ "joke" :mad::(:mad:
  12. Spice Weasel Husqvarna
    UK
    08 SM610
    What did you spend 500€ on?
    Your clutch housing can be TIG welded, i know i have a TIG welder. V the crack out a bit to its full depth then fill with weld, i would go for 4043, you could tidy up the weld after with a file if you take time and care. I would put a steel dowel the same size through the hole and weld around it, knock it out when finished to leave a neat hole. It wont be an expensive job :thumbsup:
    Maybe the retaining plate could be used as it is, or maybe it could be straightened a bit?
    I dont think the rivets you got were the correct ones.
    I peened the rivets myself, cold. I put a hammer in my vice, put the back of the rivet on it and used another hammer with a large flat ended drift to flatten the end. It was surprisingly easy, I believe you could do the same yourself with the correct rivets. I surprised you got someone else to rivet your clutch housing.
  13. John Tsoukalas Husqvarna
    Greece, Athens
    TE 250
    Duke 790
    "I peened the rivets myself, cold. I put a hammer in my vice, put the back of the rivet on it and used another hammer with a large flat ended drift to flatten the end. It was surprisingly easy, I believe you could do the same yourself with the correct rivets. I surprised you got someone else to rivet your clutch housing." the same thing I did.
    I think that this machinist ( lathe operator as you said) should not ever touch a tool or a power tool again. Maybe a desk job...I cannot imagine what would happen to a wireless keyboard without battery though by his hand...HAHAhahahahahHAHAHA...
  14. mg94 Husqvarna
    Italy
    SM610S
    XT600
    Following motranqui's reasoning, higher preload on the springs means higher force required on the springs in order for them to compress, which means more stress is transferred (technically 3x for Spice Weasel) to the other parts before the springs do their job, and that's not ideal. I remember some posts back some users reported that the wear had been transferred from the bushings to the clutch basket, and this could be the reason. I am due to check my washers too, I think I'll have them made on purpose, but retaining the original thickness, but I do also have a cush hub on my 610.
    motranqui and Theo like this.
  15. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    You guys are way over thinking this.
    My assumption was that the original IndyUlimited spring cup washers were made thicker so if they did wear again they wouldn't come apart so easily. If the material is stronger it's likely they won't wear anyway. I haven't heard from anyone with the update done, what it looked like after another 10K miles.
    Anyway, get a set, replace them, and sleep well. Ride the piss out of it. ;)
  16. Kt06siggm1 Husqvarna
    08 sm610
    None
    Does anybody have a definite source for the cup washers? I tried Stuart from Australia. I can't find a way to get in contact with Indy and if they are still making them. Any help would be appreciated.
  17. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Finally:
    320€ clutch housing
    15€ retaining palte
  18. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Spice, how did you manage to shape the upper part of the rivet in a "round" way?. Do you hit the rivet laterally? I ask you because if you hit it from up to down it could simply happen that the body of the rivet fill the entire diameter of the hole (which is what the turner has done) but you can not make a rounded shape on top.I'm a bit concern that it can happens again...
    Indy unlimited adviced us :
    • Take the unit to a bike shop to rivet without damaging your clutch basket. (what I did without success, as you know :()
    • If you do it your self remember it takes 2 people to rivet this with an air hammer and anvil. You must support the head inside the basket and rivet the back side with the air hammer. I takes about an hour since the rivets are very good quality.
  19. motranqui Husqvarna
    Madrid (Spain)
    Yamaha YZ 250 F
    Could you explain in more detail how do you manage to make this work? Did you make it on your own or did you need help? Which way do you grab "everything" while you hit the rivet? How did you get the "round shape" of the rivet?
    Thank you
  20. Spice Weasel Husqvarna
    UK
    08 SM610
    I ordered the rivets and there was more than needed in the packet, so i sacrificed one in an experiment and put it on my vice and hit it with a hammer to find out if i needed to heat them up before riveting them. I found the rivets to be surprisingly soft, and decided no heat was needed.
    Like i posted before, i clamped a hammer in my vice to reach passed the fingers of the basket and use as an anvil and started off using a big flat ended drift and ball peen hammer to try and get a nice neat flat profile, but just ended up using the ball face of the hammer. I didnt hit them hard (like REALLY pound on it) I took my time and flattened the end of the rivet with many smaller blows.The results i got were very similar to the picture in CJBROWN's post you quoted My clutch is still good with about 8000 miles since. HTH :thumbsup:
