250-500cc Help me decide on WR250
Discussion in '2 Stroke' started by RusRider, Oct 30, 2011.
  1. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    If you don't have a "cage" in the air filter it will try to suck in on you. You need to get a filter cage.
    Did you find parts diagrams?
  2. RusRider Husqvarna
    I have it done already. Without cutting the pipe, just drilled it off. Air vent cutted and welded. But that's not enough. Looks like it's smith else in the pipe that restricts exhaust flow. I've found out it with air compressor. Compare with my old yz pipe it clearly has smith more inside. I was thinking to cut all the pipe to see what else is inside but not sure I can weld it back.
    I've made the cage out of airrestriter, looks almost like original)))
    No I haven't found parts diagram nor online parts supplier. I'll appreciate if somebody can help me with it.
  3. giantjoe Husqvarna
    Canadia
    2010 WR300
  4. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    2013 HUSABERG FE 350 ,2014 KTM 300XC
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Get it jetted correctly and it will start 1st kick. Yes you have to get up over the bars a little and kick down and back but once you get the technique down it's no problem.
    I have an 09 WR250 that I ride in the woods and I prefer it over my GasGas 200 with Ohlins front and back, which is known to be one of the premier woods bikes made.
  6. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    been kickin this bucket of bolts for two days now, after an experienced committee of riders have taken their shot of it ,studied it carefully , and used EVERY technique to fire it up ...and we did get it running at times.its no premier machine, my foots black n blue my knees swollen and i can barely walk. jetting maybe an improvement once its running buts there more than that going on here.gonna load it up and return it . lets see what they say
  7. lankydoug Husqvarna
    MO
    WR
    TM 300en
    When new, mine was jetted rich and the float level was too high, it would want to foul the plug and I'd kick until I was wore out. Now it's one kick even when cold. I lean the bike to the left until it pees out the overflow, pull the choke and first kick it's running. Yours will come around with a little tweaking... hang in there.
  8. TROFFER88 Husqvarna
    Camas Wa
    check the spark plug cap
  9. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    i pull and clean the plug, we checked the gap as well as spark, i lean the bike to the left to let out the overflow, choke on or off, fuel on ,then fuel off etc etc . you name it we tried it . when we do get it running and let it get hot it still wont restart and the longer it runs the crappier it runs !! if i ever got stuck in a technical spot in the trails im screwed ! and getting the bike into neutral when it does run is like the wheres Waldo game. because of the mis-designed placement of the kick-start lever you have to prop up the bike or place a milk crate under your opposite foot to stand the bike up . and im 6'4"
  10. WoodsChick Administrator
    Oakland, CA Miramonte, CA
    KTM, GasGas, Suzuki, Honda
    Do like Troffer88 says and check the spark plug cap. This was a problem on our `09 WR250, and a few others here have experienced the same thing with their WR's. That bike came very close to being shoved off a cliff until we figured out that it needed a new spark plug cap that fit better. It now starts within one or two kicks each and every time :)
  11. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    spark plug cap?
  12. WoodsChick Administrator
    Yep. Seems the one on Eric's WR250 was loose or something, as it wouldn't make consistent contact. The bike wouldn't start, Eric would pull the spark plug to see if it was fouled, it wasn't, he'd put it back together and it would fire right up. A few miles down the trail it would run like crap and then die and not start again for love nor money. Off the plug would come, everything would look ok, the plug would go back on, bike would start and run great...lather, rinse, repeat....all day. We switched out the stock plug cap for an NGK one (don't remember what the difference was) and the problem disappeared, never to return again.
  13. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    ill check it , but even after pulling the plug and cleaning it it still dont fire
  14. WoodsChick Administrator
    Maybe there's a loose ground somewhere? Are you consistently getting good spark? Take your kill switch off and then try starting it.
    I don't blame you for being unhappy...you shouldn't have to mess with a new bike just to get it to start.
    windsurf likes this.
  15. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    just went through the whole thing again !! no luck , thanks for the help . im going to return the bike to the dealer and get the bike i originally went in for. the husaberg 300 ,E-Start and a 6 speed or the 300 xcw
  16. windsurf Husqvarna
    queesland
    I had problems with the kill switch causing an intermittent misfire/stop evry few hundred metres. Just unplug it behind the headlight shroud. It takes two seconds to disconnect / reconnect and is worth a try.
    I know you shouldn't have to with a new bike but, for the purpose of getting it started to sort out jetting why are you kicking it? give it a push.
    Without trying to antagonise you are you sure you really want a two stroke? Any make will require jetting wether it is electric start or not. As I am sure most on here will agree it is worth perservering with the Husky as they are just as rewarding if not more so than any other brand.
    So far as the kick start, once you have the bike running properly they do usually start 1st kick meaning the kickstart position doesn't make any noticable difference.
  17. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    What jetting do you have in there now?
  18. braddenning Husqvarna
    Northern NJ
    2011 WR 300
    aside from these issues , as i study this bike its a horse an wagon in a a world of modern transportation.its low price and for some good bang for your buck but you get what you pay for. steel frame, 5 speed ,very basic bike like a 1970 Hodaka that should only weigh about 210 to 215 lbs yet weighs the same of other 300s and some 4 strokes with e-starts and 6 speeds etc. im not knocking the bike but if it was 15 lbs lighter than the KTM or the other 300s than i could justify the lack of conveniences .i still like the bike , besides i was told it was a 6 speed when i bought it
  19. TROFFER88 Husqvarna
    Camas Wa
    Go orange and go home
    utopia likes this.
  20. lankydoug Husqvarna
    MO
    WR
    TM 300en
    It sounds like you bought the bike on an impulse and it probably isn't the bike for you. You spent the time to read the spec sheet and learn the weights of various bikes yet you didn't know it was a 5 speed when you bought it.. seriously?
