Temp sensor is not very expensive, $30 or so. I'd also have the TPS set with iBeat when you get a chance. Could be an issue. Like setting the timing, only a bit more.
Thank you all for your help!!! I Received a new temp sensor (the updated version) form Hall's today, installed it and....Voila! I just touch the button and it fires and idles.Beats the hell out of cranking and goosing for 4 minutes rach time.
Also replaced my temperature sensor with updated version . Now he starts immediately and the fan is not always on. I also added a flashing red light when the fan is operating
Im now having problems with my temperature sensor. It measures .260 K ohms when cold, so its faulty and its the updated 8000H3649 one. Never had any starting issues, just the fan comes on randomly and sometimes stays on.
about 20 degrees Celsius , normal value and about 2420 ohms . if it indicates about 250 is definitely broken
The newer temp sensors have a different part number from the original one. Do we know if the newer ones are any more reliable than the stock version or should we start buying them in bulk quantities expecting them to fail within a couple years as well ?
I ordered the temp sensor from Husky Sport before dinner yesterday, and it arrived this morning, so another shout out to Husky Sport for their top notch service. The bike seems to be working properly now, with the fan cutting in and out when it should, will see how long it stays this way. I checked the "faulty" temp sensor again, and it seems to be operating correctly, so it must be intermittently faulty. I am getting the correct 5v from the connector to the sensor.
Both the faulty one and the replacement are like that one, they are both the updated 8000H3649 part number, as i stated in post #25
Hello rotax , hello everybody. Please have you the link for sensor temp buy ? My bike is difficult to cold start.
where I bought it I do not recommend it for long waiting times. however it will not be difficult to find it from one of the top 10 sites indicated by google by entering the spare code
excuse the question but have you had an anomaly with flashing of the light of the mad of the gears and verified with ibeat that the temperature sensor is broken?
I have just a problem start cold. I hesitate betwenn sensor temp ( i have the oem ) and ibeat low settings is too high.. And my screw of slow idle is too loosened I think the pu higher the mixed
What are your ibeat settings? How old is your battery? If your idle is set too low it could be difficult to start. .
