any luck on getting parts FB?
if you can't find anything local let me know and we can overnight it all to you. (as could any dealer)
Interesting! Of my six Huskys in the last 10+ years..... I've only had sprocket bolt problems with my '00 WR250 and that was because I was in denial about my swingarm bearings being shot. Sprocket bolts were coming loose from the swingarm moving and putting chain out of alignment. New bearings, no more loose sprocket bolts.I have owned a LOT of bikes over the last 30 plus years and I have to say husky has an issue here. I have never seen another brand loose more sprocket bolts than husky. I do not know what it is but it is true. Before I owned huskys I never really thought about sprocket bolts. Now I am checking them all the time after seeing MANY fall out and one like the poster here on a NEW 08 TXC510 with maybe 150 trail miles. Is it the bolts, the design, what?
I do that, but it seems they still deform a little over time..Always tighten the nut not the bolt. The bolt will bind up as it interfaces with the sprocket countersink.
They were about $250 for a rear hub last I checked, and it did NOT include bearings/seals.Used, or new from Husky? I think a new hub from Husky is something like $500-600, but I could be wrong. Not sure if it comes as just the hub, or as an assembly with bearings etc.
I think that is what has happened on my bike (which is a TE450). I had no problem with the stock sprocket and bolts. Nothing ever came loose. Then I put on an aftermarket rear sprockets and the countersinks might have not been quite a s deep as on the original or something, because a couple of my bolts came loose last weekend. I had them all torqued down when I installed the sprocket last year, and I re-torqued them yesterday, but I don't think that the nylon is grabbing the threads. I will probably go the Lock-tite route with them.On my TC450, the bolts are about 1/4" too short. The bolts don't reach the nylon portion of the lock nut and are subject to coming off frequently.
Keep after them! They have no excuse not to warranty these repairs. It is not a questionable failure. Loose sprocket bolts are a known issue with these bikes. Parts should have been ordered the same day you brought in your bike. I worked as a motorcycle/showmoble/small engine mechanic in my last life and I can tell you they are just giving you the run around!Week 1 update:
The bike has been at the dealer for a week now. I am sorry to say that no repair work has been done.They are waiting for warranty authorization from Husqvarna before ordering any parts or starting the repair work. Not the way I would do business, but repairing my bike seems to be low on there list of priorities. I will give them another week and then I may have to crate my bike up and ship it cross country to a dealer like Hall's Cycle in Springfield, IL. I'll post another update as soon as I hear some news.
FB
