Holey Flap! my bike eats shock covers fast
Discussion in '4 Stroke' started by ARH, Sep 17, 2012.
  1. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    check out http://www.gearingcommander.com/
    it'll tell you EVERYTHING you need to know about teeth wear, chain length, wheelbase, speed, rpm, gear shifting, stretch, and geometry. you'll be able to change virtual sprockets or chain lengths to see each effect.
    te450dean and Teambowles like this.
  2. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    We generally center axle in adjuster with the marks then get the chain as close in length to that. A good quality chain will stretch but should not stretch enough to be longer than what you have left on the adjuster. After the first few good rides you should be about done adjusting your chain, maybe minor tightening adjustments after that. I have a real problem adjusting my chains I always over tighten them then have to go back n loosen them up lol.
    Trenchcoat85 likes this.
