Holy grail of frames I found it......
Discussion in 'Vintage/Left Kickers' started by Bigbill, Oct 18, 2016.
  1. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    I checked my 2 bikes once with a degree finder, i saw no difference. 468790_577098772322249_1757448192_o.jpg
    unlike these 2, its so easy to see
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    That's interesting. Of course, If you're just measuring the angle compared to ground, it would also depend on your suspension sag at that moment.
  3. Picklito Husqvarna
    Washington
    Can Am's with adjustable rake? Eccentric bearing cups? Still sounds like just a trail adjustment to me. Does anyone have a photo?
  4. 86 400 XC Husqvarna
    Calgary
    more Huskys
    No sag, i was checking it because huskydog said here take a 84 frame with the steeper forks.
    I will get some pics on the weekend, I know they were same lol but it was 3 years ago
  5. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    I saw one of the adjustable rake Can-Am's at a vintage MX race two seasons ago. After puzzling over it for a while, I realized that it does change rake and trail rather than just than just trail. The offset on the bearings would change the angle of the steering shaft through the steering head. I believe the bike's owner said it could be set to either 27 degrees or 31?? (not sure). Here's a photo of the offset bearings I found online.
  6. Bigbill Husqvarna
    '83 250wr
    0 right now
    Different degrees on the fork plus a shorter or longer swingarm effects the turning radius. Which swing arm is shorter the cr or wr in the evolution bikes?
  7. Picklito Husqvarna
    Washington
    SteveJ,
    Thanks for that. You show exactly what I was hoping to see: The races are spherical, so you could change the upper or lower and yes, change the angle of the steering stem in the frame rather than just move it forward or backward. Very cool.
    Bigbill,
    Generally, the CR & XC were the same, but longer than the WR.
  8. Bigbill Husqvarna
    '83 250wr
    0 right now
    Wouldn't the longer swing arm add the extra two inches of travel on the cr & XC?
  9. Joe Chod Husqvarna
    upstate NY
    No.
    That's not how it works
  10. Picklito Husqvarna
    Washington
    The extra swingarm length does add to the arc length, but the CR/XC shocks have longer travel, too.
    Joe Chod likes this.
  11. can Husqvarna
    Canada
  12. oldbikedude Husqvarna
    Honey Brook Pa.
    I thought the evo's swingarms were all the same length wr,xc,cr ?
  13. Bigbill Husqvarna
    '83 250wr
    0 right now
    Two different lengths.
  14. 86 400 XC Husqvarna
    Calgary
    more Huskys
    Single shock bikes all use the same length
    justintendo and oldbikedude like this.
  15. oldbikedude Husqvarna
    Honey Brook Pa.
    Thanks 86XC...I thought so
  16. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    yup, the end of dual shock/steel swinger was the end of the different length swingers. 83/84 still had 2 different lengths.
  17. Bigbill Husqvarna
    '83 250wr
    0 right now
    Is there an advantage to having two different length swing arms?
    How about the different degrees of rake on the front fork?
  18. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Can-Am shows the the angle is built into the bearing cups used as there are timing lugs on the cone races that require specific orientation to set the target fork rake.
  19. can Husqvarna
    Canada
    Here is a picture of the Canam "cup and the cone". Made of aluminium, the cup is pressed into the steering head with the 2 grooves pointing to the front and back. The cone has one nub that allows it to be reversable.
    Ingenious system which works great.
    Outer diameter of cup is about 60 millimeters. So steering head is quite a bit bigger than a husky and would require welding in a new steering head tube.
    SteveJ, Eurofreak and justintendo like this.
  20. jimspac Husqvarna
    Connecticut
    The reversibility gives plus or minus rake so you getting 2 settings from each cone set. A Husqvarna with that setup would really be the Holy Grail of frame.
    A triple clamp with reduced offset will change the trail number only. Pulling in the rake angle produces the same effect
    SteveJ likes this.
