How Big A Tank - FI TE610
Discussion in '610/630' started by Howard70, Dec 25, 2008.
  1. knary Husqvarna
    PDX
    el bumpo :D
    200+ mile range
    250 would be great
    any more and you're running a super tanker.
  2. Mike Kay Husqvarna
    California
    Some one needs to check in with Aqualine and see where they are at. Thats a hint. :)
  3. knary Husqvarna
    PDX
    Last week they told me, "Thanks for the feed back, it looks like the tank for the TE610 will be available towards the end of the year."
  4. Mike Kay Husqvarna
    California
    Now that is some bad news. Guess its time to convert an '08 bike to work with an '07 IMS tank...remote fuel pump. Plan B. :confused:
  5. knary Husqvarna
    PDX
    Any guess on price? Aqualine's stuff is usually a bit spendy - but quality.
  6. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    Any indication on the size? To me much more than 5 gallons will be awkward if not done particularly well. If your that far in the boonies you can always carry more......
  7. An-tonio Husqvarna
    Spain
    One question ... the only difference between the FI model and the carburetor is the fuel pump? the IMS tank can be fitted smoothly into the chassis of the FI model ?
    If the only difference is the fuel pump I think it's easy unplug fuel pump from original FI tank or look for another fuel pump an attach it in some place. Nobody tried this ?
  8. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I don't understand why every FI bike I can think of has the pump in the tank. There must be a reason. If the fan was removed there would be a big hole to put a pump in. Someone here will chime in with the answer, I'm sure.
  9. knary Husqvarna
    PDX
    The fuel acts as a lubricant and coolant. The pump is further from the heat of the engine. The pump is less likely to try to push the vapor as there are fewer opportunities for an external leak. And all of this means a cooler operating conditions, and less chance of the fuel boiling. Added together, there's MUCH less chance for fire. Fire is bad. :D
  10. From RV (as of this AM),
    Thank you for your enquiry, because there is still a lot of design and development to be done on this tank I do not have a lot of information but it is looking like it will available towards the end of the year. Feel free to contact us again in a few months or keep an eye on our web site for updates. Regards, Nicole
    The quintessential stall....
  11. BTW, this inquiry was for my carb'd '06 TE610.
