How to adjust idle on TE 630
Discussion in '610/630' started by Carsondriver, Sep 2, 2011.
  1. mekanik Husqvarna
    Kootenays, Canada
    open ended wrench either 5/16" or 8 mm. it really isn't too hard, with bike running just dial her into spec.
  2. Russ Husqvarna
    Sydney
    TE250i & 701 Enduro, 501 & 630 sold
    Thanks, I knew it was either 8 or 10mm but wasn't sure which.
  3. peteSD Husqvarna
    San Diego, CA
    2011 TE630
    thanks for this topic... the owners manual has to be the worst i have ever seen!
    pumped up the idle and it doesn't die when slamming the binders on at a stop light anymore.
  4. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    If you haven't installed the power up kit, do so. That will cure your stalling issues.
  5. shoolsema Husqvarna
    Vancouver, Canada
    can anyone tell me what this screw does? I didn't look close at the picture and i adjusted this jam nut/ellen key thing and it also changed the idle? it must move the cam thingy that the throttle cables rotate?
  6. peteSD Husqvarna
    San Diego, CA
    2011 TE630
    im sorry.. do to my lack of energy to look up what the "power up kit" is... can you tell me what it is? I have the Husky Arrow pipes and ECU.. plus my dealer did all the obvious de-corking mods... Thanks in advance!
  7. shoolsema Husqvarna
    Vancouver, Canada
    P/U is removing the O2 sensor and putting a 2.2ko resistor in its place. I think it puts the Fuel Injection into "open loop".
  8. SimpleOne Husqvarna
    Sydney, Australia
    TE 630
    09 ZX-6R Trackbike
    I've hit a small issue with idle speed, I can't seem to drop it enough, its sitting about 1800 at the moment (started around 2000). No matter how much more i turn the idle speed screw counter clockwise, it won't lower the idle speed any further. I assume there is a limit to the degree of adjustment this screw offers?
    Can I wind the screw back in a bit and reset the idle speed through iBeat or something in order to put the screw back in a useful range of adjustment?
