How to start an Husqvarna CR450?
Discussion in 'Vintage/Left Kickers' started by atelier.nm, Aug 13, 2017.
  1. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    an old trick is to run a longer fuel line and allow it to do a loop below the carb, this acts as a natural trap for crap. or use a filter.. you can use staright 20 wt briggs and stratton engine oil for the gearbox. for the air cooled bikes i would run a mineral based two stroke oil such as valvoline or tts at 30 :1. Maxima should be fine as well and smells good.
    chuck a handfull of nuts and bolts in the tank with some soapy water and do the shimmy shake for a while. this will sandblast the loose crap off the walls. rinse well then slop some metho around in it to grab the water out as a finisher. if it needs a liner it it, follow the instructions carefully
  2. atelier.nm Husqvarna
    London
    1973 Husqvarna CR450 Desert Master
    Triumph Scrambler 900 custom Sof70s
    I just want to provide an update to everyone that might have had a similar issue.
    If the bike doesn't start check the ignition for spark, an old bike is bound to need a new ignition the bing carb also needed to be rebuild.
    1- I installed a new Mikuni carburator, mainly because it was the option everyone with these bike goes for and it also includes a choke, therefore super easy to start the bike.
    2- Ignition had a spark, but it seemed very weak, therefore I also decided to install a new electrex electronic ignition. Again this seems to be what everyone goes for.
    After both Ignition and carburator were installed even after an entire year in storage, the bike started first kick.
    I've also just managed to register the bike with the DVLA as an historic vehicle to get it road legal with a Daytime MOT. After just 10 days the DVLA sent me the V5C with an age related registration plate, nice and easy.
    DaveM and Steve-F like this.
  3. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Sweet :thumbsup:
    Good to know that by combining a carb with a choke and an ignition with an electronic advance makes these old 450's easier to start. I wonder how far the ignition retards the timing to achieve easier starting.
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Carb an ignition numbers please. I kicked the shit out of mine this weekend and no start. My leg and lower back are paying for it now. Chris
  5. atelier.nm Husqvarna
    London
    I bought the Mikuni carb with a bolt on conversion kit from Chuck Cureton at Huskyjunk.com it's a nice and easy job to install the kit.
    The ignition was completely beyond my knowledge, therefore I asked for help from Lee Perry at Husqvarna Man which is just one hour drive from my house. He got a brand new electrex electronic ignition that is specified for a 1986 husky but mixed a few parts to build a bespoke one for my bike. Lee as got all the merit and amazing knowledge of all husky models, he even builds bespoke 4 stroke husky.
    I can tell you the thing is very easy to start now, but I've also installed a decompression valve to make it easier, which is shown on one of the earlier posts.
    The only concern now is that you need to check all bolts and nuts are tight each time you ride it or you'll start losing parts along the way.
    DaveM and DeathFromAbove like this.
