250-500cc How to tame my WR250
Discussion in '2 Stroke' started by roj0000, Mar 8, 2016.
  1. roj0000 Husqvarna
    Wr250
    XR250 RVF400
    thanks JAM you just saved me about $20 bucks!
    NCSteve likes this.
  2. JAM Husqvarna
    South Carolina
    2012 WR144
    2017 Beta Xtrainer 300
    You are more than welcome. Least I can do for all the great help enjoyed from the generous members of the forum.
  3. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    thanks from me too
    Just on the lowering compression option - extra base gasket just wondering if anyone has done this ?
    I am mainly trying to make my 300 easier to kick
  4. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    I do use 3 Base gaskets...
    This will lower compression but also do alter Port timing and make your engine revs more...
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Hmmm...interesting. I'm about to do piston rings on my 300 and have a few extra base gaskets. So far I was just going to do the rings, replace the same gasket, then if she still kicks and starts hard try retard the timing. I could have a squish issue, but not sure I want to decrease compression or change port timing :confused:
  6. Miezie666 Husqvarna
    Germany
    When i was rebuilding my engine i saw the Transfer Ports not fully open with only 1 Base gasket. As i m a 125 rider f more than 15 years i decided to take away some bottom end power an adding some overrev instead.
    NCSteve likes this.
  7. rockdancer Husqvarna
    If its got a .5mm gasket I was only thinking of adding a .3mm or another .5mm gasket
    I spoke to someone at a ride a while back who new someone in Brisbane that does decompression head conversions ( like on the 360 ) but I don't know who that was
  8. rockdancer Husqvarna
    If you add a lot of base gasket thickness I d say you'd need to get the head machined to correct a too thick squish band or it will be harder to jet correctly
  9. rockdancer Husqvarna
    To retard the timing a fraction how much would you turn the stator plate ? 1mm ?
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    From another post
    "don't get too bogged down a couple mm BTDC and try it if it seems flat advance it, if it sounds aggressive and or pings retard it"
    I'm thinking 1mm at a time
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    You got a spare head an a few hundred i will make you a decomp head.
    But its a 250 you dont need one!
  12. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Often thought of trying to fit a decomp head to the 360 but after looking at the work required in welding and polishing...might spend the dollars on maintenance.
  13. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I got one sat on my shelf doing sweet FA
    Its got chainsaw decomp in it and a 10mm sparky thread, if you find an auto decomp with 10mm thead then your off.
  14. rockdancer Husqvarna
    Juicy - finding a spare head might be hard
  15. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
  16. ohmygewd Husqvarna
    Aprilia RSV1000
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup that beauty would be perfect.
    If you actually are serious bout the 360 head then shoot me a pm.
  18. ohmygewd Husqvarna
    Aprilia RSV1000
    Cheers mate l will!!!
  19. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    haha..."... It is possible to restart the engine during flight...." I want one! :cheers:
  20. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
