husky 430cr
Discussion in 'Vintage/Left Kickers' started by Barry Ranson, Nov 7, 2014.
  1. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    the engines are not numbered to the frames. the frames state what year and model they are. long as you have an 85 motor in an 85 frame, it is "correct".
    I've also seen late year bikes with the next years plastic, I had a 83-1/2 CR which was sold as a 84. It had a 84 WR tank, 84 seat & side covers & a very high frame serial # for the year & was sold thru a very small dealership in Conn.
    Husky made bikes with the parts they had on site, if the model year was wounding down & the next year model were almost ready then some of those parts were used too. There's was NO on time , next day parts delivery back then, what they had, got built.
  2. Bigbill Husqvarna
    '83 250wr
    0 right now
    Sorry I should of noted air cooled 390 / 420 / 430 use the double reed box setup.
    The liquid cooled bikes use the newer rectangle reed box.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
    I guess husqvarna pushed out what bikes they could with the parts supply they had in the early to mid 80's.
    The transision to liquid engines had to be tough. Even the change to the single shock.
    I still find the twin olin gas shocks the best suspension there ever was even today. There's a frame to swing arm flex I feel on the single shock bikes of today. I feel the rear tire is steering trying to pick another line when leaning. I wonder if the dirt bike designers will see and understand what this flex is doing? Someday thell wake up and say oh look what we discovered "twin shocks"???? DA??
    I could go as fast as I wanted too with the twin shocks. The swing arm never bounced. The old front forks wether 38mm or 40mm worked fine. Now today there is so much adjustment in everything we need the engineer who designed it to make it right. My guru bike buddy says the dealer who sells the bike should setup the suspension. At least close for the purchaser. Every new rider thinks you just get on and ride. I get the adjust what? They don't have a clue what's race sag? What's rebound? Then it's the bikes fault when they have problems riding it. Each individual riders weight and style is different. Why are the suspension settings so fine tuned on the newer single shock bikes?
    Give it just three settings? Light, medium, hard. Then change rear springs and fork oil weights to set it to the riders weight. Keep it simple? Why so high tech?
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the later 430 ac used the box style as well
  5. Bigbill Husqvarna
    '83 250wr
    0 right now
    The 390/420 has a 71mm stroke while the 430 has a 74mm stroke. That's only a 3mm difference. I believe the 420 gets close to the 430 in the bore size?
  6. Kartwheel68 Husqvarna
    Newnan, Georgia
    I've never seen an air cooled 430 with the box reed cage, do you know what year had the box reed? The '83 was the last air cooled 430 as far as I know and it had the old reed cage.
    The 420 is the same bore size as the 430 with 3mm less stroke.
    oldbikedude likes this.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Bill,
    There is a big difference from the now modern machines versus the old vintage machines.
    We are running faster, hitting stuff harder, and flying longer in the air/further. This is stuff I wouldn't even dream of hitting on a vintage bike at those speeds. Who would of thought that instead of ordering needles and jets, plus a lot of guessing versus hooking up your laptop and changing your air/fuel mixture in 5 minutes? Soon you will see the exact same stuff on a modern two stroke.
  8. justintendo klotz super techniplate junkie
    if there is anything i dislike about a certain vehicles suspension its that you cant externally adjust it. i try to get my suspension dialed in as best as possible, and im constantly learning better ways to do it. if someone is confused by having rebound and compression clickers, its not the manufacturers fault
  9. idefix Husqvarna
    South Germany ( Bavaria )
    WR 390 / WR400 / WR250 / WR300
    Yamaha YZ and a modern Moto TM 300
    Hello visiteur,
    to you know where a 430 motor is for sale ?
    But no dead part please .... :)
    IMvintage likes this.
  10. visiteur1948 Husqvarna
    france Europe
    husqvarna only
  11. idefix Husqvarna
  12. Goliver Husqvarna
    1983 500CR, 2017 FC450
    KTM 1190 AdventureR,Harley Road King
    I know I’m super late to this party. I just signed up to be member of this forum. I just bought 1983 500CR and the frame is Husqvarna 1 CO16340. The engine number is 0945 6813. Don’t know any history on bike.
    DeathFromAbove likes this.
  13. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Screenshot (181)a.jpg Start a thread on you new bike and we love love love PICS!!!
