HUSQVARNA1 CR500
Discussion in 'Vintage/Left Kickers' started by 2premo, Oct 29, 2016.
  1. suprize Husqvarna
    Bendigo, Australia
    ktm 300
  2. brian bush Husqvarna
    Colorado
    '93 WXC360, 2018 TC150
    A few KTMs and Husabergs.
    They say a picture is worth a thousand words.. Here's me on my new (to me) baby - an '82 Bobby Grossi works bike replica made from a 1984 500WR. She's got 6 speeds and is plenty stable at speed!
    DaveM, SteveJ and Michel Dufayard like this.
  3. oldbikedude Husqvarna
    Honey Brook Pa.
    Yes? No? Maybe so?
  4. mudmonkey Husqvarna
    brian bush likes this.
  5. DaveM Husqvarna
    Adelaide, Australia
    2001 TE 570
    Motorised Bicycle
    Nice Bike!
    I can see your smile,
    even with the helmet on!
  6. brian bush Husqvarna
    Colorado
    Yup, it is a smile machine for sure Dave!
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    excellent...how good is that engine?
  8. brian bush Husqvarna
    Colorado
    Seems like a very good engine. Very broad powerband. Soft and usable down low. Builds power steadily and relentlessly to a major mid-top. No surprises and easy to ride. Very easy to start - literally on the first kick every time if I use my right foot (My left foot is still learning.) It is in amazing condition and the quality of the workmanship on the paint and powder coating of the frame is first rate! Steers more with the throttle than the bars, compared to my other bikes and has the excellent stability I was looking for. High speeds are this bike's domain!
    Can anyone tell by looking if I have CR suspension on this bike? I suspect it may be but don't know how to tell for sure. I know some of the gurus can tell with a glance..
  9. brian bush Husqvarna
    Colorado
    Oh ya, and I almost forgot. The vibes on this bike are not near as bad as they were on my '85 500xc. Ya, you can feel 'em but not any worse than other big bores I have ridden. Also, the seat on this thing is the most comfortable I have ever had!
  10. brian bush Husqvarna
    Colorado
  11. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    quickest way to tell if its a cr is to check for a "floating" rear drum.
    judging from your pic it looks like xc suspension to me..which is cr ride height. tall...
    those do not look like 84 wr forks either, as they have less underhang below the axle. maybe looks tall for a wr too. wr would have also had a rear frame loop, but yours may have been cut. im betting the whole bike is an xc.
  12. brian bush Husqvarna
    Colorado
    Thanks Justintendo, I think you're right. It is hard to see in the picture but the forks are raised quite a bit in the triple clamps too, so they seem longer to me than WR.. The VIN makes it a WR but I think when it was rebuilt to look like Billy Grossi's works bike, XC or CR parts were probably used. At any rate, it rides and runs really great, so I'm happy regardless of where the parts came from : )
  13. oldbikedude Husqvarna
    Honey Brook Pa.
    I would be too. The bike looks great.
  14. justintendo klotz super techniplate junkie
    sure, no problem with a "custom built" swede! they interchange well. someone likely just cut off the rear subframe loop.
  15. slosh Husqvarna
    82 wr 430, 84 wr 500, 86 cr 500
    93 Husqvarna wr250, 99 Suzuki rmx250
    Hi, I have a bike with similar frame number. It is a 1986 500 Motocross, also has no engine number. Mine has been a bit of a curiosity in that it has a six speed gearbox, WR rear sub frame and headlight, but CR frame. Is yours the same?
  16. justintendo klotz super techniplate junkie
    not much curiosity..no engine numbers means replacement cases..someone likely just put a wr subframe on. these parts mix easily
  17. oldbikedude Husqvarna
    Honey Brook Pa.
    Were the CR's six speeds back then? I thought they were 5 speeds. Do you have the rear brake with the link to the frame?
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    if you check the parts manual, you can see the two different fork sliders..wr and cr / xc along with the different damper rods. the shockers are altered by removing a travel limit spacer..voila! cr suspension on a wr = xc (plus a few other bits..)
  19. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the six speed is common, sub frame was probably replaced on yours, headlights were not possible on a stock CR due to the ignition being internal rotor with no generator for lighting circuit
  20. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    sounds like a std XC to me...they used the cr brake
