125-200cc I made my own 165 Kit
Discussion in '2 Stroke' started by Miezie666, Apr 5, 2016.
  1. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I just searched here for powervalve or power valve. Here's what I snipped from the info:
    Set the power valve linkage as advised by WB in one of the tacked threads, 3/4
    from the top (best for woods riding).
    You have the 7 transfer port cylinder with the older big power valves (??).
    Adjust the arm so there is ~.040" of deflection in the upper spring keeping the
    valves closed. Probably about 1/3 of the way up the slot. No need to adjust
    further and if you do you will compromise top end with the bigger power
    valves(the bottom doesn't clear the exhaust port completely).
    I expected to keep adjusting to get it just right, but runs great :cheers:
  2. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
    Well done Miezie!
    I still regret (german: nachtrauern) the 175 IT I had in the 80th. A 175cc smoker is the best engine you can have.
    I'd like to have a WB165, but the shipping to europe...
    So I'm waiting to the TTIP ;)
    jeanjean
  3. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    I will try to get another 165kit ready- i m sure it will run better than this one i ve got now. I have to get it on the same performance Level wallybeans kits are! I m sure there is some room for improvement...
    And i hope TTIP will never be real!
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the ol' gunnar gasser! they are a pretty slow ratio but a great throttle. the original whirlpull. something like 110 degrees close to open.
  5. Athla125 Husqvarna
    husqvarna sm 125 2006
    Hi
    Wanted to ask (a bit late) how is it with yours 165cc kit? I wanted to ask if its nikasil and which piston are these? Amd if possiblem what do i need to do to make it or can i buy it in EU?
    Thanks alot
