125-200cc I Rode The Prototype Wr200 And It Is Amazing...
Discussion in '2 Stroke' started by Motosportz, Dec 22, 2011.
  1. Vinduro Husqvarna
    Mississippi
    Here is my setup thus far 144cc vs 167cc. I am sending Walt a FMF 200SX pipe at end of week. As good as the Uptite kit is , I can see advantages of Walts 165cc kit. I don't think the port timing is changed because of the piston that Uptite uses because there is a spacer plate to bring everything back to norm. BUT, you would for sure lose crankcase compression. That will effect performance. Back in the early 70s , tuners would stuff the crankcase to up the compression. Also Walts piston is lighter. Note my jetting is with a 36mm not 38mm carb.
    Year & Bike Model = 2011 WR150 with Uptite Husqvarna 167cc kit.
    Carb = 36mm Keihin PWK A/S from 2011 KTM 150XC
    Pipe & Silencer = FMF Fatty WR125 pipe / FMF S/A silencer (going to try a modified FMF KTM 2003-04 SX200 pipe)
    Other engine mods = Exhaust spirngs Stock / silver.
    Premix ratio & fuel type = Maxima K2 @ 40:1, 100LL AvGas / 110 Sunoco race gas mixed 4 gal AvGas to1 gal Race Gas.
    Temperature range (deg F) = 65
    Elevation (feet) = 300ft. to 1,700ft ASL
    Main jet = 170 (144cc = 175)
    Pilot jet = 35
    Needle = NOZH (NOZI stock) (slightly richer needle so I could run on #3 position and keep more needle in needle jet.
    Clip position = #3 NOZH richer than stock NOZI #3
    Air screw setting = 3 (144cc = 2 3/4)
    Slide = 6.0 (stock 7.0)
    CHECK YOUR FLOAT SETTINGS. Mine was too high and overflowing when you hit bumps or slightly leaned the bike over. Set Keihin at 14mm
    No bogs now gone. 21mpg.
    Gearing 14T / 50T Parts Unlimited Xring Chain.
  2. Motosportz CH Sponsor
    So what is your opinion of how that runs?
  3. Motosportz CH Sponsor
    I have a 2010 TC250 and my buddy has a 2011 TE310 with JD tuner. The WB165 with KTM200 SX pipe feels like it has more power to me to. And i think i need a slightly smaller main and it will gain even more top which is already VERY good.
  4. Motosportz CH Sponsor
    Don't be, the WB165 flat rips the head off the 144, no comparison and you will never look back. Seriously.
    spud1968 likes this.
  5. Vinduro Husqvarna
    Mississippi
    Thus far, Top end seems the same with more and smoother low and mid range. For sure produces enough torque that you need to gear a lot taller. I put on a 14T (had a 13T) and could barely tell the difference until the upper gears where it actually seemed to pull better. I am putting on a 50T rear (had a 52T) for sure and I run tight woods. Before dropping the main two sizes it would blubber just as it came onto the main then clean out. Usually after running at lower rpm in the woods for a while. No blubber at all on needle or bottom.
  6. john01 Husqvarna
    Powhatan VA
    Very good Kelly; thanks. Hey the WB165 runs on 93 correct? Hope so that way I won't need to remember to make sure I have 110 oct as I run a mix of it and 93 with my 144. Hey K my bike is an 08CR so should I look for an older jug or just send the current set up when you are ready with the kits?
  7. Motosportz CH Sponsor
    Thanks for the info. Will be interesting to see what you think of the 200 pipe on there.
  8. Motosportz CH Sponsor
    Mine is running pump gas, thats how Walt set it up. The 08 jug will work fine. We are waiting for the next batch of pistons.
  9. john01 Husqvarna
    Powhatan VA
    Kelly I know it's early in the sale stage for the WB165 but what is your best guess as to when the kits will be ready for sale? What will the down time will be after placing the order? How complete will the kit be? Do/will we need additional gaskets etc.? Will we need to remove/re-install the PV's or send the whole upper end to you for exchange? Hope all this hasn't been asked and answered. Thanks, John
  10. Motosportz CH Sponsor
    We have several cylinders getting reworked right now and are awaiting the next batch of custom pistons. Everything will be included, bolt on kit. We will need your cylinder and powervalves setups to redo for the next kit. Cylinder and everything but the PV cover and actuation arm. If you want your exact cylinder back we can do that too but would take additional time. The original idea is get this stuff in stock (end of the month we hope) and simply do exchange. Make sense?
    Thanks.
    potter likes this.
  11. potter Husqvarna
    france
    very good
  12. john01 Husqvarna
    Powhatan VA
    Perfect sence and easy for us garage hacks, thanks K.
  13. Vinduro Husqvarna
    Mississippi
    Kelly, Did you get my order out for the 2 front sprockets ?
    Dwight Rudder
  14. Motosportz CH Sponsor
    you know I'm glad you said something as I saw it in PP but it never showed up in my inbox. Will get it out tomororw. Will also refund some shipping.
    thanks.
  15. Motosportz CH Sponsor
    Buddy Blake posted this of us riding Saturday, me on the WB165 in front...
    jmetteer likes this.
  16. john01 Husqvarna
    Powhatan VA
    Sweet video! What are those big jungle looking green plants in all your videos; bigfoot food LOL? Looks like an awesome place to ride.
  17. Vinduro Husqvarna
    Mississippi
    That was one 13T and one 14T for the current 125-150 Husky.
  18. Vinduro Husqvarna
    Mississippi
    That near Mt. Baker ?
    Dwight
  19. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    Nah, that one is in Oregon. Pretty close to where they used to hold the Trask ISDE qualifier back in the day. Did you come do any of those?
    Later,
  20. rancher1 Husqvarna
    WA
    The green stuff are ferns.
