I solved the/my "noisy" engine problem (and it's not what you may think it is)
Discussion in '4 Stroke' started by RedRims, Jan 17, 2010.
  1. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Have you had any weird side affects with modifying the auto tensioner?
    Veryquick likes this.
  2. sean bromley Husqvarna
    whaley bridge, high peak, uk
    te450 2007
    it did feel a little tight when I was first trying it out so I backed it off a bit more, then went out on the trails and after say, 20miles it started to rattle again so I increased the tension a touch, then continued on my way, and it sounded fine. I must add that I've left a bit of space between tensioner and nut, it's not just tight in there. but I may take out the tensioner, remove the spark plug and turn the engine by hand, and with a probe or screw driver, find the tightest spot on the chain, then refit tensioner and adjust from that point.:excuseme:
    Shawbridgehusky likes this.
  3. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Keep us posted. I think this is an awesome idea. I can't tell what mine does. I have an 08' te510 and upon cold start up, it sounds like something is not building pressure in the oil system or the tensioner is allowing the chain to be too tight. If you blip the throttle over 3000rpm and let go back to idle, it sounds normal. Only when cold and no difference with whatever brand oil. Done it since I got it with 695 miles and now has 2600 miles
  4. sean bromley Husqvarna
    te450 2007
    i'll keep you posted on how the modification goes. have you removed your tensioner and bench tested it? when i say bench test i really mean whacking the ratchet against a vice or similar and you may find the tensioner retracting upon whacks. this is not good. my '07 te 450 sounded like i was opening and closing my kitchen utensil drawer 1200 times per minute. all i can say is check the tensioner and if it's no good try an ape manual one or drill and tap the standard one to stop the ratchet retracting when it should be tensioning.
  5. Veryquick Husqvarna
    2007 husqvarna sm610
    2009 Yamaha r1. 1998 Harley
    Hello I was going to ask if the exhaust pipe on the 07 sm610 will get in the way of a manual timing chain adjuster and do you have to find TDC before installing the manual timing chain adjuster???
  6. cjoecruz003 Husqvarna
    Vacaville, Ca
    2006 SMR510
  7. Veryquick Husqvarna
  8. sean bromley Husqvarna
    te450 2007
    I decided to go all the way and make a manual tensioner, I removed the ratchet, spring and Pawl , sent a m10 tap right through, then found a suitable length bolt, ground the head until round then fitted with copper washer and lock nuts. Just enough clearance with the starter. And does the same job as an ape tensioner would. Covered 300 miles so far with no issues.
  9. hammered Husqvarna
    99 te610
    I had a 94 610 that sounded like a can of marbles
    Funnest bike I have ever owned though
    My 99 is the same after owing it a couple months now
    Going to try this fix you guys have happening here
    Simple and anyone can do it
    Thanks for the thread
    Excellent read and figure it should get bumped up for others to read
    One other thing I am finding is the clutch baskets and spring shims are nfg
    This is one other big issue on these bikes with engine noise
    Nice bikes but some issues that need attn
    Good thing this form exists so fixes can be found the easy way
    Shawbridgehusky and sean bromley like this.
  10. Shawbridgehusky Husqvarna
    Quebec Laurentians
    TE450 2008
    Good thread, just found it. I will look into the one on my new to me low mileage '08 TE510.
    I think the idea of a manual tensioner is very good, but will require more attention
    over the long run as chains do stretch. Then there is the possibility of over tightening
    which will create rapid wear on the components. Best bet is to use finer threads and
    make checking it part of regular maintenance.
    One of the posters above was right about setting it at the proper place as chain tension
    is never constant throughout one complete cycle. So removing the spark plug and finger
    tightening with attention is the way to go.
    I can see how the auto tensioning devise is useful on production 4 cycle motors
    as they self setting and no two motors will ever be alike. That and the average
    owner does not have the skill to set it.
  11. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    I put the Big Bore Thumpers dot com MCCT on our '08's. The 510 was easy to set adjustment, the 250/310 was a pain because of the cylinder being lower and behind the mid pipe. I got them both installed and set and they are revvin' along nicely. I put some permatex thread sealant on them for good measure. I would put MCCT's on the 630's if they were available. I trust a MCCT with me wrenching it.
  12. Flynn Husqvarna
    England
    Do you know what my options are with this tensioner:
    Everyone seems to assume the ratcheting type is the only type, but this one is smooth.
  13. TheRealBuzz Husqvarna
    2009 te 450
    Is this a hydraulic CCT?
  14. Flynn Husqvarna
    England
    Apparently it is just a regular auto tensioner but my problem is every thread I find on the internet is about the ratchet type rather than this type. This is what it looks like apart:
    I am having some worries as to whether it is doing it's job or not, take a look on my "610 engine rattle" thread and tell me what you think.
    Edit: Just found this video of a DR650 tensioner, the Husky one is the same but smaller:
