AndrewS
I would just add that regarding point 2 above, I think your iBeat setup is working properly. Since there (apparently) aren't any fault codes, none are showing up in iBeat.
And since you don't have the lambda sensor installed, you can't adjust FB on your bike. The only real drawback to that is that the default settings on the JD tuner assume that all 3 points are at 100. You might want to get in touch with JD to see what they recommend for settings given your 98 100 100. It will probably be a small variation from default. (For some reason, I thought 2008 bikes only had 1 adjustment point. I must be mis-remembering.)
Also, you are correct about the above diagram.
