iBeat / Semco EFI info
Discussion in 'EFI/carb' started by Motosportz, Nov 30, 2009.
  1. crille74 Husqvarna
    Sweden
    Husqvarna cr 125 2014
    Yes.
  2. 04asphalt Husqvarna
    SW Michigan
    this statement still hold true?
  3. raisrx251 Husqvarna
    Virginia
    Not really, this was back early when the FI first came out. This was with the bad running map or stock map that never ran right. When the O2 was hooked up you were out of the race map. When hooked up to ibeat and O2 in place on the earlier models, you could read if the bike was lean or rich by trying to keep the reading at 100. The problem was that the reading was not fast enough to get a accurate reading. This is similar to Power Commander 5 that read and adjusted it automatically.
  4. James Patton Husqvarna
    Edwardsville, ILL
    TE511 2012, WR125 2006
    1250S Bandit, DRZ400S
    Will the IBeat still work as advertised on my 2012 TE511? I want one for diagnostics and changing CO values.
  5. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
