ID my Husky
Discussion in 'Vintage/Left Kickers' started by NissanMike, Jul 9, 2016.
  1. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    82 yamaha tt250 86 honda xr250
    Nevermind disregard I learned how to search correctly lol
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    its a 87 or 8 CR
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i dont see anything!
  4. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    Yah I found my original thereafter from 2 years ago. Relearned a lot haha
  5. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
  6. 84scrambler Husqvarna
    mid Florida
    More pics, so we can start all over again...
  7. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    I could do it all again if y'all want. I didn't get too far on it obviously. I rode it the one time I mentioned in that other thread then it died I got pissed yadayada anyway wore pics ok IMG_20160709_161821042.jpg IMG_20160709_183812085.jpg
  8. justintendo klotz super techniplate junkie
    so are you fixing this bike up or what? great machine, last of the swedes. my favorite chassis..
  9. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    Well. Fixing it is the plan. I've got an itch to ride and I'm hopeful that I'll be able to scratch it with the husky. Least before Christmas
  10. oldbikedude Husqvarna
    Honey Brook Pa.
    Thats a great starting point. Give it a proper cleaning, new seat cover & grips, clean the carb & airfilter (maybe get a new air filter if it needs it). Clean & lube the chain, new spark plug, and see how she goes.
  11. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    Alright guys I've got it running again. But I'm curious about the radiator cap. It's got a 13lb cap on it. Is that right? I'm just trying to cover all my bases. Tia
  12. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    run it if it heats up get a stiffer one:excuseme:
  13. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    I like that answer. I'm gonna roll with it. Thanks
  14. justintendo klotz super techniplate junkie
    ill run out and check some of my caps when i get home today..sometimes if they heat up, bad things happen or or its not the cap at fault. these engines dont really have a tendency to boil or anything tho.
  15. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    Ok thanks. I'm just being paranoid, mostly because I don't wanna kill the bike. But that's good info
  16. justintendo klotz super techniplate junkie
    in that case..there are some things to check..
    flush coolant and replace with premixed coolant or distilled water/coolant. the magnesium likes to corrode. any signs of water in the transmission oil?
    any play in the right side of crank? remove ignition cover and try moving flywheel straight up/down to check main bearing play.
    the swinger pivot bearings dry out and crack the swingarm, also if there is looseness of the nut isnt tight, the play will develop in the engine case bushing there...bad..might already be loose there.
  17. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    I'm gonna check that whole list, thanks for the heads up
  18. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    Hey I've been researching carb stuff. I have a 38mm mikuni with 410 main 40 idle 3rd clip on needle 2.5 slide. Is that good bad or indifferent?
  19. justintendo klotz super techniplate junkie
    what engine? 430?
    check the needle jet as well.
  20. NissanMike Husqvarna
    southern OR
    87 frankenhusqy
    I'm not sure on the engine. I was told 430 but idk
