nev..
Terrarist
As it is, the mag morelli technology comes in phases. The early ignition/ecu you could do this with no problem. Mag Morelli has evolved and has addressed the issue of leaving a key taped to the antenna, and now this practice has messed up ecu's in other bikes.
huh? This is no different to having the antenna around the ingition and a key in the ignition. This is how every RFID based system works. All this mod is doing is moving the antenna and the key to a location other than ignition switch.
Personally I don't see much need for this mod, other than as a temporary solution in case the original antenna or wiring is damaged. It doesn't bypass the immobilizer, which is what people really want to avoid having immobilizer issues in remote areas. I know there have been similar antenna hacks for BMWs, but these addressed issues with faulty antennas in early systems, and AFAIK have never been an issue on the Terra, and were solved in BMW models from 2009 onwards.
