IMPORTANT 2010 250 info.
Discussion in '4 Stroke' started by krieg, Apr 20, 2010.
  1. huskyfrk Husqvarna
    los alamitos Ca
    250
    O-rings should be available at any quality bearing house, they will size it up for you, get a step up in grade, you should be good to go...
  2. Steam Husqvarna
    Hangtown, CA
    on the x-lite engine it's not just an o-ring, it's like a 2" and 3/8" joined at the hip. the larger diameter seals the filter opening, the smaller seals the oil port.
    in the meantime, the permatex worked flawlessly.
