250-500cc IMS GAS TANK 3.4 GALON 09-12 WR 300
Discussion in '2 Stroke' started by 454x, Mar 17, 2012.
  1. ajaxauto Husqvarna
    2006 to 2008 CR WR
    2006 to 2012 Wr 250/300
    2006 to 2008 TE/TC all the same tank come on guys it is a dirt bike the tank fits ok I have many races with no problem Just raced the national in Idaho and used my 2006 tank on my 2011 Wr 300 the tank is 6 years old and I had no problems 3.4 gallons only get me maybe 50 miles at race speed does not matter if I am on the 125/165 or the 300
  2. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
    After having two races with the big fat tank installed, here is my $.02.
    Install was flawless, quality of the IMS tank is great. The only problem with assembly was the nutplates are a touch (maybe 1/32") to close together and I had to file out the holes a little on the petcock. I don't fill the tank all the way up, maybe .75gal from full, and I can notice the weight difference while racing hare scrambles. My guess is because the weight is carried a little higher. The width is about 3/4" wider on each side, this is noticeable upon first ride but doesn't effect me while racing. Would I like to have my stock tank back? yes. Do I regret buying the IMS tank? No
  3. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    Thanks! Now I gotta save my $. I ran out of gas at 45 miles last weekend on a 50 mile loop....thankfully I had 2 msr fuel bottles in mt camelback
  4. ajaxauto Husqvarna
    If you are only filling it up .75 of the way up Why are you then using the IMS tank A stock tank is 11 quarts.I run a extention on my stock tank with a dry break and the tank holds 3 gallons now.So for races under 45 miles I run the stock one and for longer races I run the IMS
  5. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
    Price, I looked at getting the dry break add on but didn't want that. Some of our races will be around 50miles, so 3 gallons will be pushing it. The last two races have put me right in the reserve window with 3 gallons in the tank.
  6. mhambone Husqvarna
    Pine Mountain Club, CA
    81ae420,87xc500,09wr250,09sm610
    Husabergs,Maicos,KTMs,BMW
    2008 TE is fuel injected therefore a different tank to house the fuel pump
  7. Palito Husqvarna
    Ontario, Canada
    2009 WR300, 1986 430AE Auto
    1989 DR600
    Do you have any photos of the extention with dry break, where did you get it, and was it a difficult install?
  8. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    How are you guys running out of gas at 45 miles? I did 60 the other day and still had just under 2 gallons left in my 3.4 gallon tank. I did 110 miles on a tank once. And no I don't just put around.
  9. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    I get close to 60mi on singletrack with the stock tank before turning on reserve. But in the desert, not so much. I ran out at just under 40mi once when I was wfo a lot. Typically, I have to pull a higher gear and keep rpms low and can squeeze mid 50's out of it if I am in the desert.
    I did 100+ miles on my old yzf426 with an IMS 3.4 gal tank, but never got that out of a 2 stroke.
  10. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    I usually ride trail but that 110 mile day had about 50 on a road tryin to get back to camp. We were far from camp. Then we took a wrong turn. 30 miles in the wrong direction. That sucked. The bike really sucked it down then. So I understand.
