Innovate Motorsports LC-1 and ibeat tuning
Discussion in 'EFI/carb' started by Tech 3, Jul 18, 2011.
  1. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    Yeah i saw alohar1 from SMJ inquiring about that. Said it will run atleast 1K! pretty scary.....
  2. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Yeah it is pretty scary but for now I am going to work with my F/I today and see if I can get
    the idle down and keep the right TPS settings I will let you know.
  3. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    i wish we could figure out what they are using to tune F/I in s1/s2 supermoto races... they seem to have good running/winning bikes..
  4. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    B_M_F I'm going to do a little reverse engineering on the
    EFI today and I might come up with something for ya.
  5. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    im praying.. you have me very curious! off subject anyone know what size feeler gauge i need to check the valves? also what shim sizes incase they are loose? If i were a betting man i would guess your going back to carb?
  6. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    I think I have a way you can set up your F/I with out the I beat I am working on it right now
    I will let you know later on today
    And I think I am going to stick with the EFI
    The carb swap is a lot of changes I think I am gona keep tweaking the EFI
    valves 10-15mm intake and 15-20mm exhaust
  7. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Alright I thought I might of had something for ya
    My thought was that If the tps was set to 100.2%
    at WOT,
    which in my case yielded a 1001 mv reading
    at the TPS setting
    and my idle speed is between 1950 and 2150
    and my air screw is 3 and 1/2 turns out.
    Then why not warm the bike up,
    then shut it down,
    then set the air screw to 3 and 1/2 turns out from stop,
    then start the bike up and set your idle to 2000 rpm
    this should set your tps real close to the 100.2% at WOT
    and 1001 mv On the TPS
    and it does, I have repeated this quit a few times
    the problem is with out the ibeat there is no way to except
    and save these new values to the ECU.
  8. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    hmmmm where are you getting the reading for the TPS volts?
  9. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    I am getting the reading from the I beat, the ibeat reads out mv and WOT%
    so you can check one against the other, but the problem is being able to
    accept the new mv reading by clicking the set button with the mouse
    to make it flash to the ECU
    I tried to contact Scot at semco today to see if he ever thought of setting up a
    rental program for the ibeat that would give people a option who did not want to buy one
    In BC mats EFI tweak it says the way to read the mv with a volt meter
    and i think the wires are the black and black and orange wire
    I would read there to know for sure
    Shoot me your email address and I will send you the ibeat manual
    Then things will be a lot more clear as to what is going on.
  10. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    B_M_F I shot it out to ya twice and it sent it back both times
  11. B_M_F Husqvarna
    San Antonio, TX
    08 SMR 450
    Fixed it!
  12. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    still sending it back
