Intermitant Fuel Pump Failure
Discussion in '610/630' started by proeasy, Jul 29, 2013.
  1. nathanbird24 Husqvarna
    Scranton Pennsylvania
    2012 txc 250
    Thought about the switch. Lights go on when I click the switch tho. It's just damn $40 for a relay.
  2. R_Little Husqvarna
    NJ
    I had the same problem on my 2010 TE250 when it was new....100 miles.
    Was racing an enduro in a long fast sand section and I hit a log hard and the pump stopped....took it out of the tank trail side with guys ripping past, plugged in the wires and the pump started!....put it all back and rode off to the check out 50 minutes late.
    Next section..same thing took it all apart..spilled gas all over myself, located the one lost screw in the leaves and rode to the checkout 55 minutes late this time.
    Last section the bike was fine, made it to the check out and the bike stalled. Was pulled into the pits by a 1990 DR350S
    Dealer replaced the pump with one from another bike and hit has been fine since.
  3. nathanbird24 Husqvarna
    2012 txc 250
    Well mine isn't doing thy when running. Just if I shut the bike off then a few minutes later turn the switch to ON and then it won't kick the relay til 10-30 seconds later. So I don't think it's the fuel pump failing. Thanks though
  4. organ donor Husqvarna
    Berlin
    So it´s still an unsolved problem. I thought I had got mine sorted out. It started straight off like new. And today it started on the out ward trip and then took a long time on the starter for the trip back home. I´ll check the connector under the tank as it looks as if it´s the fuel pump.
  5. Troup Husqvarna
    Tornaveen Scotland
    Honda CRF - KTM SX
    I am currently stranded with this problem.
    Bike was running fine until I stopped for 5 mins.
    It then would not prime the fuel pump and the neutral led does not light.
    Any one else had this issue with the LED?
    Pretty sure it is a wiring issue.
    Fortunately I have found somewhere to stay for tonight so will get a look at it in the morning once it has stopped raining.
  6. Fast1 Husqvarna
    Minneapolis, MN
    not sure what to recommend but a bump to keep this thread at the top for some assistance.
  7. Troup Husqvarna
    Tornaveen Scotland
    Honda CRF - KTM SX
    Got back home. checked all looms and connectors. they are not pretty but could not find the culprit.
    I can force the pump to prime and the neutral led to light if I rapidly press the start button on and off.
    Then it starts and seems to run ok.
    What could it be?
  8. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    It could be the starter button, connection or relay.
  9. Troup Husqvarna
    Tornaveen Scotland
    Honda CRF - KTM SX
    Thanks, been looking at the schematics and I have a hunch that it is one of the relays. will get them tested tomorrow.
    Once I have fixed this I want to sort out all the wiring.
    It is disgusting.
  10. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    I got a Hi-Flo for a lady friend of Mine's X-Challenge --worked for about 10km and that was it busted. Trouble was we brought it in from overseas -
    My one 610 gave problems and I put in one from Cycle works --same as the ktm 690 pump --works like a dream for over 25,000 km already now --
  11. Blazes Husqvarna
    South Africa
    Try the relay as the man said --could be the problem --
  12. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    If it turns out to be the pump, we carry the high quality efi pumps from Cycleworks. We also have low micron stainless steel rebuildable filters.
  13. Troup Husqvarna
    Tornaveen Scotland
    Honda CRF - KTM SX
    Cool thanks. It has worked perfectly now for several days. Carrying a good spare relay in my jacket and waiting for the fault to reappear.
    I am pretty sure the pump is ok, it had a new one only 1000 miles ago.
    Good to know you have pumps, It took me ages to get one out of Italy!
  14. EricV Husqvarna
    Are they indeed for the 630? If I look at the ca-cycleworks site I only see one for the 610 (and another, but it's a four hole mount.)
  15. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You must adapt it to fit and swap out the stock filter for stainless like OHR did in his thread. The cycleworks pump is 30mm like oem and not 32mm.
  16. EricV Husqvarna
    Gotcha. I'm due to go back and read more of OHR's experiences anyhow- great thread that guy has going.
  17. STEVEL Husqvarna
    U.K
    TXC 250 2013
    KTM450 EXC 2006
    Hi what fixed the problem as i have the same on a TXC250 2013, stopped fueling after a break, the red light may flicker and it will try to fire but then wont light up and no fuel pump noise!!
    HELP!!
    I have changed both fuses inside the right panel with no luck i got a flicker of red light and a small fire but didnt catch and now no red light or fuel pump
    ANY IDEAS ANYONE?
  18. tommyk Husqvarna
    630 sms
    zx10r
    hey man, i had pump problems....priming...then not priming....let me down a lot, so much i lost faith in the bike. dealer was no help either.! got a new pump from the US ...fitted it..not a problem since
  19. HuskyBrutha Husqvarna
    SM630
    690 R, 500 EXC, XR250
    Well, it would seem my 2010 TE510 is behaving like most everbody else's bike on this thread.
    Run it for +30 minutes, switch it off. Switch back on again and fuel pump wont prime.
    Let it cool off for +20 minutes, switch on and the pump will prime again.
    Run it for a bit, switch off and on again and the pump will not prime. etc etc.
    Gonna try the relay first, then if that don't work I will replace the fuel pump.
  20. STEVEL Husqvarna
    U.K
    TXC 250 2013
    KTM450 EXC 2006
    Got it sorted, it was the plug connector from the stator/generator, it had burnt and was shorting. Replaced with a HD plug job done!
