Intermitant Fuel Pump Failure
Discussion in '610/630' started by proeasy, Jul 29, 2013.
  1. Rob Gordon Husqvarna
    Tomball, TX
    2009 TE 250
    I've been having the same problem with my 2009 TE250, where did you buy the replacement pump? I checked the dealer and the OEM pump is pricey, $642...
  2. mandolin Husqvarna
    Hungary
    SM 610 ie '09
  3. pinocono Husqvarna
    Here's one a little closer to Texas:
    http://www.ebay.com/itm/13-Husqvarn...ts=Make:Husqvarna&hash=item2c7d8d36ae&vxp=mtr
    Or you can go this route:
    http://www.ebay.com/itm/Intank-EFI-...Parts_Accessories&hash=item2eca2d433f&vxp=mtr
    I have no connection with either of these sources, I just did a search on ebay motors for "husqvarna fuel pump".
  4. TE 450 Pilot Husqvarna
    Ontario Canada
    I had mine rebuilt for around $200.00 all in. I just dropped off the bike and picked it up when done. The whole pump likely does not have to be replaced.
  5. mekanik Husqvarna
    Kootenays, Canada
    Of course you need to replace the pump, you don't need to replace the whole assembly though.
  6. HuskyBrutha Husqvarna
    SM630
    690 R, 500 EXC, XR250
    Well it turned out that the relays were not at fault in this instance.
    So I dropped in a new fuel pump and problem solved.
    Interestingly the fuelling was really crappy for the first half hour of riding on the new pump with lots of flame outs etc.:confused:
    After numerous stops and starts the EFI eventually sorted itself out and bikes running great now:)
