JD TUNER Died on my TE511
Discussion in 'EFI/carb' started by huskydude59, Jul 26, 2014.
  1. huskydude59 Husqvarna
    Berwick
    Yep I have the same... Am a bit confused on primary and secondary. They don't state which is which. Using the mmeter I get an open circuit on plug cap. And maximum allowed on pins 1&3.
  2. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    Pins 1 & 3 are the primary coil. Pin 2 to the spark plug connection is secondary.
  3. huskydude59 Husqvarna
    Berwick
    Well gotta cost for the coil ...$240..ouch. Problem is I am not confident that its only thing wrong, or if the coil is at fault.. The values I am getting a aren't giving confidence to go spend the $240. Plugged the "faulty" coil back in and it started really well, but did not want to rev out...It wouldn't run off idle, only coughed and spluttered. I checked the spark and it seemed really strong. I Have good fuel pressure, no faults coming up either.. Am wondering if the ECU is playing up..
