All 2st Jetting Chat - Need Help? Post Your Questions Here
Discussion in '2 Stroke' started by Johnnymannen, Mar 24, 2010.
  1. Falcon Husqvarna
    Australia
    Te511
    Hey Husky Bro's I'm in Australia , I have bought a 2013 Wr 300 , will I have to change jetting ?
    The dealer is taking off the restricted expansion champer for road & putting on the offroad one , if this makes a diff!
    Can someone explain what exactly happens , with the Mikini?
    All info will be great help , Cheers
  2. old3 Husqvarna
    NJ
    Follow up on my 99 WR125 with the closed air screw...
    It started and idled at about 2500 RPM if I had to guess, got that turned down and it sounds a lot better, throttle response was far better too. I was only able to ride around the house a bit but after 10 minutes of mostly low to half throttle the plug was taking on a coco brown color on one side. No spooge!
    About half the times I went WFO, I felt a little stutter as it hit mid range. Mostly going slightly uphill, the downhill with same throttle it pulled right thru. Fat on the needle?
    It was only 50f today, I guess it'll get worse as it warms up if it is fat there. Pulls so much better with the air circuit open. One step closer!
  3. Hellmet Husqvarna
    Brisbane
    Wr 250. Husky boy jnr 50
    Dt 175. Pitt bike 250.
    Sorry 390 main & 35 primary,changing to a380 main & 32.5 primary,I keep fouling b8es plugs!
    Any idears what I should set needle to,was thinking the middle notch?
    Bike is wr 250 2001..
    Cheers.
  4. nonamerider Husqvarna
    Oklahoma
    61 needle 2nd from top 4 side 32.5 pj. what oil and ratio. 4 slide
  5. animalmark Husqvarna
    wre125
    hi husky wre125 need help jetting ive derestricted exaust but need jet size
  6. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
    My bike runs like shit now that i have changed to a pro-circuit exhaust, lots of spluddering on low throttle openings and it dies of in the midrange for a second or so before it reacts and goes on. I have some issues with jetting clearly, could someone please help me. Stock Mikuni carb.
  7. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Don't know about the Pro Circuit, but my WR250 has the FMF Gnarly and I had go three sizes leaner on the pilot, it likes the stock needle and 400 main pretty well though. Probably go leaner on the main when the weather heats up...
  8. lankydoug Husqvarna
    MO
    WR
    TM 300en
    With the gnarly I went leaner on the pilot 32.5 and GAY needle in the middle and richer on the main 430.
    Stock pipe was stock needle 35 pilot and 390 main.
  9. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
    Maybe my setup is too lean, my mj is under 400 now.
  10. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    Sounds like you are too rich in the lower ranges not too lean up top.
    Harbinger likes this.
  11. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
    Thanks for the replies.
  12. Falcon Husqvarna
    Australia
    Te511
    Has any one got jetting for Wr300 2013 ?
    Runs good but idle is up and down & stalls in corner hard on the brakes .
    Any info would be great. 400 /40 / stock needle & position
  13. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    I finally had the chance to ride this bike (11 CR150/FMF pipe) long enough to be able feel it out and make a few adjustments. My 04 RM125 has this carb, and it was set up correctly right out of the box. The Husky, not so much. I had a little weakness, almost a (lean) stumble in the mid throttle, and wide open exiting corners. It wouldn't hit hard, even with a stab at the clutch. Considering all the spooge I have, I wen t a notch lean on the needle, wondering if that's where it was coming from. Wrong. It got worse, so I went a notch rich from stock, and that did it. It hit's HARD on turn exit, and even if I'm a little low in the rev-range, it still comes on hard, and pulls clean until the next gear. After that adjustment, and when it was cold, I tried starting it without the choke. It fired in 10C weather, so the spooge is coming from too much pilot. If anybody else had the same problem, let me know what size pilot fixed it. I'm guessing 30 should do it.
  14. belogerer Husqvarna
    WR 360
    I recently bought a Keihin PJ - runs like a dream when idle but....
    lots of smoke..
    its fouling plugs like crazy - plugs are wet...
    lacks in power - power valve not workin - i think its not going enough rpm for power valve to open...
    please tell me what main should I use and what neddle ? or what should I do to make it work...?
  15. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Hey Falcon...where about in Oz are you from?
    Check this thread http://www.cafehusky.com/threads/new-and-improved-2-stroke-jetting-database.27395/
    The googles docs spreadsheet will be real helpful to you ...2013 WR300 will no different to 2010 onwards 300's as they all used the same carbs and really hasn't changed motor wise since then.
  16. ohmygewd Husqvarna
    Aprilia RSV1000
    Belogerer...PJ's are really finicky carb's so much so that guys with RMX's ditched them for Mikuni TMX's or PWK due to the same symptoms as your experiencing with the 360 - the choke idle screw combo was one of those "what the hell where you thinking?' moments!!!
  17. belogerer Husqvarna
    WR 360
    Its not about thinking but about budget...it was very cheap and after I did a lot of reading I think there is a chance to make it work...still waiting for answers on what main/needle should I use...
  18. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    2011 WR300 - PC Platinum 2 snapped.
    Stock exhaust back on.
    Just put in Sledge racers setup and test rode...IMPRESSED
    TMX
    #5 Slide
    Gay needle on middle
    50 pilot
    440 main
    Air 1.5 out
    Very crisp, sounds different, pulls hard from the bottom and doesnt seem to end.
    Leaner slide and heavier Jets.
    Doing a 9 hr day on Sunday of very tight technical and slow terrain with an abundance of Logs from sea level to 3500 feet.
    See how many times I can boil it!?
    Picking up the 11.5L IMS tank tonight so will pop that on too.
    Stu
    SHY UK likes this.
  19. Gogo Husqvarna
    wr 250
    I'm looking for a original setting of dell'orto vhsb 37 for an wr 360.......could someone tell me?
    Many thanks!!!
    Enrico
  20. ohmygewd Husqvarna
    Aprilia RSV1000
    Throw it away rather quickly!!!
    Dell'orto was a pain to jet and even more painful keeping it jetted...your best bet is a 2nd hand TMX mikuni from the WR250, Keihin 38mm PWK or Lectron.
