250-500cc Just bought a 2014 WR300. What carb/jetting?
Discussion in '2 Stroke' started by OUMX117, Jun 9, 2014.
  1. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Hmmm. My JD Kitted bike idles very nicely. The Terminator clutch cable fixed almost all the drama with the draggy clutch. I have even kick started the bike in gear a couple of times.:thumbsup:
  2. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I've thought about the cable. I'm sure the draggy clutch adds to the idle. But like I said, It's only been a problem once since 2011. I've also found that certain gearbox oils all but eliminate the clutch drag. Out in the dessert, never a problem.
  3. Jhunter Husqvarna
    Atlanta
    On Saturday, I ordered a JD Kit for my '08 WR250. I rode a WR300 on Friday with one and it was a huge improvement. I have the Terminator clutch cable and its money well spent.
    Dirtdame and Motosportz like this.
  4. Johnny105 Husqvarna
    Clovis, New Mexico
    13 WR250 (Sold), 14 WR300
    12 KTM 50sx (daughters), 14 RMZ450
    If anyone needs a cable. I have one and other things I am going to post in classifieds since I am Huskyless.
  5. Armikso Husqvarna
    Wr300-10 te610-08
    KTM sx65
    I like mikuni more than lectron. Lectron has cheap aluminiun slide what wears out quite soon and fine tuning is very difficult.
    Dirtdame likes this.
  6. wrtimmy Husqvarna
    2014 WR300
    Lectron. 110% Lectron.
    I had less than 100km on my WR300 when I bought her, and the hard starting and off jetting immediately drove my insane. After spending a couple of weeks researching on here I bit the bullet and ordered a Lectron. Less than an hour to install on a bike I'd never taken apart before, less than 30 minutes to get set up, "jetted" and ready to ride and give me a plug reading I was very satisfied with, and gave me a great boost in power over stock jetting and rideability. Simply cannot rate highly enough.
  7. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    I don't get how you guys are reporting a 50% decrease in fuel consumption. Isn't that also a 50% decrease in engine lubrication? Why would the Lectron allow the engine to run that much leaner, and still be ok?
    Armikso likes this.
  8. 2 stroke fan Husqvarna
    none at moment
    more than a few..
    Its called atomization..
  9. Kyle Tarry Husqvarna
    Portland, OR
    Does atomization somehow increase the amount of oil going into the engine? :confused:
  10. Motosportz CH Sponsor
    Some get 3-4 mpg better, some as high as 10 mpg better. That is no where close to 50%. Amsoil spills out my muffler so I think lube is fine. Motor runs and looks new inside. I have a lot of miles with these on several bikes.
    I just snapped this pic the other day, this is an old plug. Bike runs perfect for me.
    I don't fully understand it either but it seems to be consistent. I believe the atomization is part of it but also think the lack of overlapping circuits like on a pilot/needle/main, system is more efficient and does not vary rich lean rich lean as much. My theory only. BTW I take none of this personal just posting info. Everyone knows I sell them so not hiding anything. Doubt and questioning is good conversation. I'm learning too. :cheers:
  11. Kyle Tarry Husqvarna
    Portland, OR
    Well, on the first page you said:
    32 from 22 is 45% more...
    That picture of your plug looks great for sure. I just don't get how it's possible! If you're using 50% less fuel, you're getting 50% less oil, period! Does that mean we could all go from 40:1 premix to 60:1 premix on normal carbs? Maybe, I guess that wouldn't be too crazy, plenty of people run 50:1...
  12. shrubitup Husqvarna
    Seattle WA
    Of the fuel you're using the same oil ratio applies. Even a gas powered string line trimmer is now reccommending 40:1 where other brands still say 50:1 on these small air cooled motors that run high rpm. I've rebuilt bikes using 50:1 with good jetting and found zero oil buildup beneath crank. IMO that's a bad thing for longevity. I use 32:1 with jd jet kit and have similar looking plugs and no spooge if on correct needle clip.
  13. Motosportz CH Sponsor
    22 mpg is bad and IMHO should be in the 27-32 range like a YZ250 will get. I mix at 40:1 (3oz per gallon) Bike does not run lean, seem lean or have any wear issues. My motors always look great inside. I have stuck with Amsoil after many interesting results.
  14. Motosportz CH Sponsor
    68.75%
  15. Kyle Tarry Husqvarna
    Portland, OR
    32/22 = 1.45455 = 45% more?
    Probably not worth arguing about this...
  16. Motosportz CH Sponsor
    Kyle Tarry likes this.
  17. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Kyle, you should ride my bike again now that I sorted out the power issue (flywheel weight related). I still have recluse, so it does takes really sharp edge off, but than bike is sooo smooth.. and I am still messing with powerjet to see if I can get more.
  18. Kyle Tarry Husqvarna
    Portland, OR
    Sorry. 50% better gas mileage, you're right, that's 70% as much oil. Not as bad as I thought, but still nontrivial... My bad!
    Obviously these things are working for you guys, I have zero doubt about that. I just wonder, with the fuel mileage gains, are there engine longevity tradeoffs that are coming with them? Hopefully not! :thumbsup:
  19. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    whoa im confused^. 32mpg is 45% better mileage than 22mpg(33mpg would be 50% better)! i can see your point Kyle but most economy woes i guess are to do with jetting & set up(overlapping circuits as stated, unburnt fuel, leaking breathers, float too high, too rich in general). either way im happy with my lectron & bottom end had plenty of oil in there when did 165 top end a month ago! at 32:1 with good oil i reckon it be sweet but yeah i guess its getting less oil per mile?!
    shrubitup likes this.
  20. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    I cant tell you exactly what mpg I get now with lectron. But let me put it this way...I am now pissed at myself for selling my stock tank. The ims I have now is overkill. There's always gobs of gas left over now as compared to before. I usually do 40-60 mile trail rides.
