250-500cc Just bought a 2014 WR300. What carb/jetting?
Discussion in '2 Stroke' started by OUMX117, Jun 9, 2014.
  1. Armikso Husqvarna
    Wr300-10 te610-08
    KTM sx65
    This only indicates that the Mikuni was jetted richer than Lectron.
  2. Motosportz CH Sponsor
    The Lectron is more efficient. You cant jet the Mikuni to run right and get that mileage. I've owned Wr250's since 99 when i bought my first new one. Lots of trying different jetting, JD jetting, Suzuki needle, YZ needle, this nozzle, that mod etc. still get about 22-24 mpg. I have a beautiful box of sorted jets and needles and nozzles and slides. I'm no noob to this game. Slap a well setup Lectron on and 28-32 mpg instantly and runs far better than the jetted carb could ever hope to IMHO. My opinion only and am perfectly fine with people liking there carbs whatever it might be.
  3. Armikso Husqvarna
    Wr300-10 te610-08
    KTM sx65
    I have been running with Lectron about 1,5 years and that carb isn't righ for me. i never get it run right. I do not want to undervalue the Lectron,I just wanted to bring a different perspective to the this discussion.
    Dirtdame and Kyle Tarry like this.
  4. Armikso Husqvarna
    Wr300-10 te610-08
    KTM sx65
    actually, I seized my bike 2 times with Lectron in a about minus 15-20 degrees of celsium after high speed running on a open road about half throttle. I live in Finland so i know what cold winter ride is:D
  5. Motosportz CH Sponsor
    All feedback is good. That said there is no reason you should not be able to get it sorted and Lectron (and me of course) will bend over backwards to make it work. I bet you just need to set it up a little better for your fuel.
  6. ERIC EDER Husqvarna
    2014 WR 250
    SUPERDUKE, GS 750 CAFE, DRZ 400
    FYI I just played with jetting on my 2014 WR 250 and dialed her in prefectly wheelies with roll on throttle up to 4 gear. It is flat out scary now and I am almost tempted to turn her into a supermoto instead of a woods weapon.
    Stock Carb
    35 pilot jet
    410 main jet
    Stock Needle 3rd from top
    Mix 42x1 Motul 800
    Full Pro Circuit works Exhuast with fresh filter.
    No hesitation or bog what so ever bike feels like its FI
    Motosportz likes this.
  7. raysaw Husqvarna
    Australia
    701 Enduro
    Kawasaki ZX14R
    Mate, go with the Keihin AirStriker - they are much easier to dial in than the Mikuni, easier start and also less tempremental. Also, change the spark plug to an EG - they dont clag nearly as easy if you go too rich on the jetting.
  8. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    The 36mm Lectron on my 300 was OK. Great mileage, easy to start, perfect plug color, but the performance was a little lackluster. I recently obtained the newer 38mm Lectron which is quite a bit shorter than my old 36mm. Much much more power. Back to what I remember the Mikuni being like on top. I put the 36mm with the MS-3 metering rod on a WR144. The Mikuni on the 144 was hopeless.
    As far as the mixture and lubrication, somewhere in the reading I've done there was a description of large droplets of fuel delivered with the Mikuni that burn on the surface of the droplet but leave the center unburned and exit into the exhaust. The Lectron atomizes the fuel to a much finer mist which results in a more complete burn. How the finer mist affects the lubrication of the engine before it gets burned I don't know. More surface area of finer mist seems like it should apply more oil to the engine with less going unburnt out the exhaust.
    shrubitup likes this.
  9. Motosportz CH Sponsor
    You should try my new 3-2m Lectron rod I designed for the 250-300. Amazing performance and MPG.
  10. Long_Stroke Husqvarna
    Logan, Utah
    Huh? How did I miss that? Are these a new thing? I'd love to try one.
