250-500cc Kick stand replacement.
Discussion in '2 Stroke' started by Blair7, Mar 17, 2014.
  1. sned2502st Husqvarna
    2011 WR250
    Lost mine, very expensive to replace with OEM. Longer bolt with nylon nut on the extra threads sticking out the back should never fall off again.
  2. mattmcphail Husqvarna
    Jacksonville, FL
    Has anyone bought an after market stand? I picked up a 2012 WR300 with no kick stand on it. OEM is usually pricey so looking for a good aftermarket recomendation if you have on.
  3. duey Husqvarna
    2009 wr 250
    2003 ktm xc 2008 ktm 250 sx
    Still looking myself might fab one myself they are spendy
  4. giantjoe Husqvarna
    Canadia
    2010 WR300
    I lost my kickstand spring. I hold up the stand with a KTM rubber thingy now, although I installed it poorly and have been using zip ties to make sure the stand doesn't fall. Maybe I'll just ditch the stand entirely.
  5. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    Anyone know where to get a husqvarna te449/511 style frame tab for the kickstand??
    I have a stock TE kickstand I would like to install on my 2000 cr125. I need the tab and bolt tho.
  6. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Any ideas for a replacement stand ?
    Mine was bent to far forward and now its been bent / snapped and modified to straight its not going up past the swing arm :o
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Take it off put it in a vice an give it a blow with a mallet to get clearance.
    ohmygewd likes this.
  8. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Sometimes (and over time), the metal frame tag gets bent out as well...bit of heat and the knockometer does the trick.
  9. rockdancer Husqvarna
    It snapped trying to heat and bend back to original shape .
    They rewelded it but the angles are wrong now in the other direction -
    I can possibly get it reshaped but the guy doesn't think its going to work
    I was wondering about alternatives
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Trees, triangle or try a universal one.
  11. ohmygewd Husqvarna
    Aprilia RSV1000
    You got a pic Rocky?
  12. rockdancer Husqvarna
    its ok I ll get him to have another crack or take it to someone else
    I wouldn't mind a pic or pics of what the angle of the join near the bolt is supposed to be
  13. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    I too have been looking for a kickstand. OEM or otherwise. My '14 WR300 didn't have the kickstand on it. The dealer had no idea where it was or what happened to it. I use trees, triangle stands and bike stands, but a kickstand is nice to have.
    I've looked for aftermarket sources, but, not found anything. Even posted a "wanted" add in the classifieds here. No luck.
    Heath
  14. rockdancer Husqvarna
  15. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    oh lord..
    i take it you have tried someone like halls and they arent available??
  16. rockdancer Husqvarna
    I think OEM is over $200 AUD
  17. ohmygewd Husqvarna
    Aprilia RSV1000
    Rocky, do you need a pic of the where the stand bolts onto the frame or stand join itself?
    rockdancer likes this.
  18. rockdancer Husqvarna
    If your stand is on the bike a close up of the stand near the bolt from the side angle - if you can
  19. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Hard to justify the cost of OEM.
    Heath
