L/C 430 right crank bearing
Discussion in 'Vintage/Left Kickers' started by oldbikedude, Aug 24, 2012.
  1. oldbikedude Husqvarna
    Honey Brook Pa.
    My Bearing came & it has 13 balls per row even though the SKF engineer said it would be 14. It does have the metal case & fill slot. It cost $102USD shipped to my door.
  2. oldbikedude Husqvarna
    Honey Brook Pa.
    I am going to attempt to post some pics of the reassembly of my motor here instead of starting another thread. stripped cases new bearings on left old on right.JPG prepped & masked cases.JPG masked & painted.JPG
  3. oldbikedude Husqvarna
    Honey Brook Pa.
    Paint turned out OK. I used duplicolor engine enamel, Ford semigloss black. I used a hot air gun to bake the paint in a make-shift cardboard oven. fresh paint.JPG right fresh paint.JPG left fresh paint.JPG
    everfree and 86 400 XC like this.
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    I used the same hot air gun to heat the cases, so the bearings fresh out of the freezer would drop right in. A quick pass under the arbor press to be sure they were seated. fresh trans bearings.JPG
  5. oldbikedude Husqvarna
    Honey Brook Pa.
    The left crank fell into the new bearings beautifully. Unfortunatly I pressed the seal in the wrong position. As soon as I reposition the seal it will be time for me to sort out the transmission parts. I have my original 6 speed trans. & a used one off of Ebay.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    looks great! please post some step by step of the tranny going together!
  7. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    Uhmmm, left side, the crank seal is on the inside of the casing on the cheek side ff crankshaft, and twin bearings pressed up against the outter screw-down plate.
  8. oldbikedude Husqvarna
    Honey Brook Pa.
    You are correct husqyhamm. That was a test & you passed. lol. Please pay close attention incase I make more errors. Actually...I brain faded! I realized I did that last night & it will be corrected by tonight.
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    OK, seal is in proper. I'm ready to inspect, select pieces, & assemble main & lay transmission shaft/gear clusters. left crank in.JPG left with crank.JPG
  10. husqyhamm Husqvarna
    South Africa
    All is well then. Just ensure that the double bearing in r/h casing has the ball filling hole on the outside, i.e seal flange, side.
  11. oldbikedude Husqvarna
    Honey Brook Pa.
    Yes, That is done. Thanks for any input / advice you can give.
  12. RTM Husqvarna
    Cornwall England
    1983 CR250 & 1988 WR250
    Honda CRF450R, Cagiva WMX250, KX500
    This is a worrying thread. I have just reassembled my Wr250 using FAG bearings but didnt know anything about the ball loading slot. The cost of my bearings was £9 including seals. ( I do buy a lot of bearings so get a good discount)
  13. oldbikedude Husqvarna
    Honey Brook Pa.
    As long as the Fag bearing has the maximum capacity & C3 rating you should be fine. Fags are high quality bearings.
  14. oldbikedude Husqvarna
    Honey Brook Pa.
    I sorted through two 6 speed transmissions late into the night. 4th gear, 4th gear bushing & 5/6th gear cluster were worn due to a snap ring not seated completely from the factory. This allowed the thrust washer between those gears to get chewed up causing my popping out of gear problems. I show the bad washer in one of the photos. The gear shaft assemblies, shift drum & shift forks on the right are the good ones I will be using. The ones on the left are spare parts at this point. late night.JPG sorting parts.JPG good 6 speed assembly.JPG bad trust washer (3).JPG
  15. oldbikedude Husqvarna
    Honey Brook Pa.
    Here are some pics of the trans., gears shafts, shift drum, forks & guide shafts in place. shift drum & forks.JPG looking down on transmission.JPG trans..JPG
  16. oldbikedude Husqvarna
    Honey Brook Pa.
    The cases are together. Things went pretty easy. Heated the bearing/case with the hot air gun. Chilled the crank shaft with Ice packs. My home made crank puller worked well. cases together right.JPG cases together left.JPG some home made tools.JPG
  17. oldbikedude Husqvarna
    Honey Brook Pa.
    Here is a couple shots of the worthy recipient. Sitting over a year like that just waiting. left reciepiant.JPG reciepiant right.JPG
    86 400 XC likes this.
  18. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    Nice work. I'm following your progress since I haven't ever split a case and rebuilt a Husky transmission.
    Thanks for posting.
    Dave
  19. oldbikedude Husqvarna
    Honey Brook Pa.
    I made a lot of progress this weekend. I painted the clutch cover, cylinder & head. I mounted the engine in the frame. jug clutch cover masked with paint.JPG clutch cover unmasked.JPG jug fresh paint.JPG engine in frame shift linkage installed.JPG
  20. oldbikedude Husqvarna
    Honey Brook Pa.
    I mounted the counter sprocket, clutch arm, trimmed the cyl. base gasket & installed the modified piston. (ports raised 4.5mm) engine in frame counter sprocket sprocket clutch arm installed.JPG trimmed base gasket.JPG 4.5mm raised ports.JPG piston mounted.JPG
