Lectron 3-2xl Metering rod.
Discussion in 'EFI/carb' started by 454x, Jul 15, 2014.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    2-3 and 3-2 are just 2 different rods..one is not the "new" rod.
    first number is top half of rod, second number is bottom end...higher number=richer....
    if anyone is confused by this, please check out lectrons site. anything that isnt 2 numbers then "xl" is a custom rod, such as the "ms" rod. that was designed by kelly for the 165 and stands for motosportz.
    "xl" refers to the newer lectrons we all have, unless you get a vintage one..those numbers a re confusing, lol
    juicypips likes this.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Crystal clear.
    All I know is my 38mm lectron is the best mod I've done.
    Think its 3-2xl an it suits 360 very well 1st kick most times choke cold and 1st kick every time warm.
    thats very likely, mine shipped with and still has the 3-2 as well. i have swapped to a shorter powerjet tube however
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yeah not to sure about cutting that down, I richened it up on PJ but don't know how little to cut off tube so I left it.
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    It was Kevin at Lectron that insinuated the 2-3xl was a new rod :confused:
  6. justintendo klotz super techniplate junkie
    you can buy different length tubes, they swap easily if you want the pj to kick in at a different rpm. a shorter tube will let the pj only operate at a higher throttle and a longer will let it operate at a lower throttle.
    hmm, maybe new for working with the 165? you can buy any of the numbered rods, i forget what the range of available numbers are..
    i think 1-4 for the first number...i see a 2-2 pictured on the site..
  7. justintendo klotz super techniplate junkie
    top end numbers go to 20, bottom end numbers go to 4..so there are rods like a 18-4 xl, lol...
    independant runner for auto applications would be sweet!
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Right I've not checked with lectron but you are the font of knowledge in this thread.. 1-20 1 refers to lean or rich
    And does the 1-4 apply the same rule.
  9. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    1 is the leanest, higher the number the more rich it is. So 3-1xl is same on top, but leaner on bottom the 3-2xl :cheers:
    juicypips and justintendo like this.
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Got some more info from Lectron:
    "Leanest to richest
    3-1M (same as MS-3)
    3-1XL
    3-2M
    All of these rods provide the same fuel at WOT. They are progressively richer on the low throttle positions from 3-1M to 3-2M."
    Assuming 3-2xl is next richer after 3-2m :cheers:
  11. justintendo klotz super techniplate junkie
    nice bit of info there...was definitely some confusion there
  12. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    sent me a 3-2xl
  13. justintendo klotz super techniplate junkie
    what was in it to begin with?
  14. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    A little more:
    "Thanks again. So 3-2xl is next richer after 3-2m?"
    "Correct. Then, to be a little more confusing, we have a new 2-3XL metering rod that we use for 250cc-350cc two stroke dirt bikes.
    It is even richer low throttle than the 3-2XL , but slightly leaner in high throttle positions."
    David Dunne
    Vice President
    Lectron
  15. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    :rolleyes:
  16. justintendo klotz super techniplate junkie
    that kind of conflicts with the owners manual, lol
  17. DTX915 Husqvarna
    wr125
    no shipped with a 2-3xl
  18. DTX915 Husqvarna
    wr125
    Well after I put my glasses on the new rod is a 3-2M starting at 2.054" ,close as I could get was 2.052 so in it went after a 1/8 turn lower correction this is much better. Supper smooth on bottom and much stronger across the middle and I don't have to wait for it, very controllable
    The rod shipped with it was a 2-3XL, worked good for trail ridding but I was always waiting for the thing to wind up out racing. Dave down in Texas really made the effort so if your not supper happy give him a call.
    NCSteve and justintendo like this.
  19. DTX915 Husqvarna
    wr125
    Ran it in the rain today, this 3-2m is faster than the other rod and far more controllable in slime with plenty of hit and really strong pull. Traction is key to me, it way to hyper with the PKW on rocks and roots
    Now this should be what I have heard all the hype was about.
    justintendo and NCSteve like this.
  20. justintendo klotz super techniplate junkie
    nice, now you know its not hype!
    DTX915 likes this.
