The adjustment on the side is a air bleed. Makes it leaner as you turn it out. May or may not need need ot turn out at all. My YZ450 runs good with it closed. Rode that bike again today. WOW.
Yup I'm sure, the rod wouldn't go in the hole at all. I can easily drill out the hole without touching the flat spot. Working in a machine shop has it's advantages.
I thought the PJ was on top of the throttle bore, but wanted to be sure. Any idea what the lower left hand side screw with the tube is for?
Definitely going to be careful about the throttle. I looked at Lectrons web site for tuning info & of course every thread here that I could find, but it's either for 2 strokes, or multi cylinder 4's, haven't found anything relating to thumpers. Hoping more 4 stroke users chime in with their experiences. For now it starts great, & idles nicely. I'll be taking it for a short commute tomorrow & the rest of the week.
That screw with the tube acts like an air mixture screw. Use it to fine tune/smooth your idle. The other screw moves the slide up or down for idle rpm adjustment.
Rather than risk disaster with a stuck throttle, I would wait for correct throttle cable with the 90 degree bend.
Okay, sorry for the delay on updates, but time to work on the bike isn't going as planned. Today I adjusted the rod a 1\4 turn leaner & mounted the carb vertically (no tilt).
First question: At what temperature should I need the choke? It's about 70 today with 70% humidity.
The adjustment tool doesn't fit the rod, holes to small. Not a big issue, I can drill out the hole to proper size easy enough, but just a heads up. Is there a difference in metering rod diameter?
Second question: My carb looks much different from the 2 smokes version. 2 adjustment screws on the left, top one seems to be idle, if I got instructions with the carb, I lost them. Bottom one has a tube?
Another adjustment screw on top of the throttle bore. What does each one do? Which ones the PJ? Is the adjustment routine the same as it is on a 2 stroke?
I watched the U-tube videos for 4 stroke & 2 stroke adjustments & in one where he's working on a 4 cylinder Kawi, he mentions that the slide is up too high compared to the other 3. I can't tell how he adjusted it, did he turn the choke knob? Still trying to figure out how I could see if mines too high or just right.
Is there a video out there on adjusting a Lectron on a thumper? Haven't been able to find it if there is.
Just trying to learn as much as I can about this carb so if an issue arises, I can fix it in the field.
Not sure if we need a separate Lectron tuning thread for 4 strokes or not, but would be nice to find any issues & answers in one thread. Maybe this thread, don't know.
) as shipped and the bike never ran better. Kevin did a lot of work on these 4 stroke carbs and he is a very busy guy so it took awhile.
Not sure what that link is. I get a page I don't have access to.Shameless plug ... http://www.cafehusky.com/threads/sm-te610-lectron-carb-skidplate-ims-tank.45377/
The carb's run and work excellent!
What would one of these set a fella back? I need to go through my carb, maybe rebuild, would be a great time for that clear float look. Always like new carbs.
sounds like you might be to lean now
I plan to rebuild my te450 08 to 530 or 510 kit. I want to order the proper lektron and I got cost for this already. 425 British pounds instead of 285 for the base carb!
Seller says that there must be added some tips..
"..its the mods needed to suit your application, to get the ultimate performance from the new combination. older bikes and 2 strokes dont need the idle circuit. we also machine the spigot and bell mouth to fit your husky inlet and airbox. things like older rm250's etc running no airbox dont need these mods.so its £285. you get what you pay for. theres no more profit in the carb for your application. just gotta be right! "
Is it profitable if I agree? where can I get a customized lektron cheaper if I can independently set up a input and a output flanges? Sorry for bad language!
