125-200cc lectron or not...
Discussion in '2 Stroke' started by marshwater, Mar 4, 2013.
  1. Motosportz CH Sponsor
    yes you did, thanks!!!
    Kelly
    Parfo79 likes this.
  2. marshwater Husqvarna
    WNC
    '12 TE449 (sold) '13 WB165
    order placed! cant wait!!
  3. marshwater Husqvarna
    WNC
    got the lectron in and installed. went 3/4 turn out with the idle screw and she idles great, all day long. now that the lectron is installed the power band comes in way late. i want it to come in much sooner. can i achieve this by turning out the fuel metering rod? or??
  4. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    The only way I can get a lectron to do that is to have it to lean as it seems to make the mid a bit vauge, was the pipe sounding a little more ring dingy as this would indicate you may be a bit lean
    My friends 125 fitted with a lectron gains power every where and even makes more top than the 39mm pwk it replaced.
  5. CelticDude Historically Fast!
    x
    I ended up turning the metering rod out 1/2 turn becuase of pinging. You could try playing with the powervalve to make it open a bit sooner.
  6. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Maybe try a more agressive throttle cam.
  7. huskybear Husqvarna
    B.C. Canada
    I'm sure a WB165 kit would help! :lol:. I would try turning the rod 1/2 turn richer and try it,if it is the same or worse, I would try turning the rod 1/2 turn leaner from where you started from. Richening the power jet may help as well,it has an effect from approx. half throttle to wide open and is controlled more by throttle position not engine rpm.:cheers:
  8. make meh samich Husqvarna
    Australia
    2013 wr 125
    1980 honda z50
    Can anyone point me in the right direction for mikuni jetting at 400ft. Got massive bog, struggles getting on pipe.
    Its a new 2013 wr 125. im waiting on my lectron, pipe and 165 kit, but it may not get here b4 the first enduro. Hoping i can get the mikuni a bit better to race with (hope i dont have to). Ive moved the PV down in the slot as mentioned but that didnt help a great deal.
    Thanks in advance for any help.
  9. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    nice name! looks DBW pantherish. ask AUSKY(dubdub on DBW) he just got 1, might be able to point you in right direction?
  10. CelticDude Historically Fast!
    x
    The biggest thing is the Suzuki jet needle. The stock one is way lean and starves the motor for fuel in the mid range. Needle 6CHY16-62 is Suzuki #13383-36FQ0.
    lankydoug likes this.
  11. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Gotta love the Cafe Husky, Bam! problem solved and faster than Macgyver could have done it.
  12. Watky Husqvarna
    Wr150
    BP 95ron
    motul 800 @ 40:1
    pilot 35 or 37.5
    6CHY16-62 needle middle clip
    Slide 5
    main 460 - 470
    This will go someway at getting rid of the bog. Adding Walts silver inner PV spring along with the stock spring will help even more.
    Husqvarna Australia's jetting for the 125/150's is too lean. When asking them about the RM needle they said the stock needle is better. Wrong! The stock needle gives you a massive lean spike in the mid range, hence the bog.
    CelticDude likes this.
  13. make meh samich Husqvarna
    Australia
    2013 wr 125
    1980 honda z50
    One of the pulls for buying my first husky was this forum. Love your enthusiasm and knowledge. Thanks for replys, I got some testing to do!
  14. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    When you say you moved power valve down in the slot please clarify. If the bolt is at the bottom of the slot this will give more power valve opening but not full closure . If you want to ensure less bog the bolt should be at top of slot
    But in my case this reduces top end
    The wr ignition and the 125 cc is also a factor
    If it was a 144 it changes things also - loses the bog mostly
    I'd have said do a the cr ignition but as that fixes bog or changes the way power comes on
    Comes on much quicker
    Since you are going to a 165 you probably don't need the cr ignition and wr may be a nicer ride
  15. Caferacerman Husqvarna
    Guys -
    Do the carb recommendations (needle, jets, etc.) pertain to the 2012 CR125 as well?
    Thanks -
