LED turnsig/tail light replacement woes.......
Discussion in '610/630' started by FredE, Apr 3, 2009.
  1. Reddog Husqvarna
    Michigan
    True.
    I just put flush mount LED's on the rear of my 08 610, and the flash rate is faster. The dash indicator works at the faster rate also.
  2. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    I have all LED's here and used this IC relay from a place probably not too far from you. It slows the flash down to a normal rate.
    Here you can kinda see how I wired it:
  3. Reddog Husqvarna
    Michigan
    Thanks BikeSPD,
    That will be my long term fix when I add front led's.
    Sicass is a good outfit to deal with. Some complain about prices, but they ship right away and have things in stock. Plus my local ktm dealer is a dealer for them also, so I can get local pickup with no shipping.
  4. SepticSkeptic Husqvarna
    Just installed the Baja Designs LED signals and taillight. The relay/module looks like the one from above, bit smaller, epoxy filled. It has two wires rather than three, the connector is the wrong kind, but not a big deal I don't much trust those connectors anyway.
    I ended up cutting all the bullet connectors off the signals and redoing them with the fully insulated flat style and filling them with dielectric grease. The connectors that BD had on there were over crimped anyway, a couple fell apart when handled. To mount the turn signals in the stock location you'll have to drill the hole out making it bigger.
    The tail light took a bit of work to get mounted in a satisfactory manner, in part due to complications from the ProMotoBillet rack on the back. As expected, color codes were all wrong, not a big deal, just label everything when disassembling the original tail light assembly.
    The tailight is mounted to the aluminum braket rather than the fender. I used rubber bushings between the bracket and the tail light to dampen shock. I watched a friends crack running down a rough trail, maybe overtightened or something, but I'm not sure so better safe than sorry. Holes are for access to the assembly hardware.
  5. Whitfield Husqvarna
    Chesterfield Va
    2006 610 TE
    KDX TTR TLR DRZ DR-S H-D/MX H-D/SX
    Tired of constant tail light issues on my 610 TE...
    I custom fit a DRC edge 2 LED tail light conversion into the stock Husqvarna tail light. It was a tight fit but I worked it out using the basic household fab stuff (Dremel Tool & Super Glue). Didn't feel too bad cutting up the sub $30 DRC 2 tail light. Thought about swapping out completely to the Edge 2 but it was a good bit smaller and I wanted to keep the stock look.
    Only snag was that the front brake lever switch was not being pressed by the lever so brake lights were on at start up. Quick check / fix and lights are working well. Added a set of 601 Led Turn signal lights too....
