Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I stayed with the 17 Rear Husky rims. Mostly due to the spokes and Buchanan's knew the sizes. I didn't want to venture into an 18" with that conical hub.
    I went 18" on Maico and I had to throw a set of spokes away, I had made up, because they were a titch too short. I ended up buying an 18 and 21 gold rim kit with spokes from VMX.
    oldbikedude likes this.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Have any of you given thoughts to using this (Emergency brake lining material) to reline a set of shoes?
    I know the Maico guys are using this material because the braking/stopping is a lot better?
    It is fairly reasonable to do and I have extra hubs to clamp the shoes in till glue is set.
    It would run me about $5 bux a shoe, which is cheap.
  3. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    What 17" tires are you using? IRC, or the Kenda K257D
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I'm using the IRC.
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    I'm interested Darin, especially for the old large hub EnduroC and Sportsmans that you can not find shoes for! Where did you get it and what is the glue? Also do they have to be rivited as well? Chris
  6. ruwfo Administrator
    NJ
    Darin,
    message Gary or call him, he was saying , to me he's got some super dupe brake mod, not sure if it will work on a older then 82 hub, though. We've been talking about making a 420CR out on my 80 390, so he's got a bunch of cool ideas. We' ll see & i'll post once
    we get further into it.
    Husky John
  7. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Years ago back in the late 70s my friends and I relined our own brake shoes with a material called Mintex,it worked out about as good as the stock shoes. We got our materials from the local brake shop. My friends had Autos and used a lot of brake shoes to slow them down so they would downshift faster. We made a steel band to clamp the shoes together after gluing them up and baked them in and oven.Can't remember what we used for bonding agent.
    Bill
    oldbikedude and Steve-F like this.
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I got the material from Mcmaster Carr and the Pliobond Glue. I have to read the directions good but think the glue sets while baking in oven at 300 degrees. We should be good to go without any rivets. It is same material as Maico guys using. I will be the Guinee pig. I have extra hubs that I plan to clamp the shoes in to bake to get the perfect form. I have 4' of material at 1 1/2 inch wide so I can cover the 30mm shoe widths and 25mm ones. I will cut any extra down when done. This woven material looks pretty bitey and gnarly with brass mixed in. I'll post progress and steps on here to do it plus results. What's worse that can happen? I can't stop and end up in a cornfield.......... Total cost was $40 bux with the glue.
    DeathFromAbove likes this.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Glad you brought that up cause he is suppose to call me one weekend. I will ask about what brake mods he is doing. Yeah! Cool! Do a thread on the 420 conversion.
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good info Bill! They might have used Anabond or Raybestos adhesive. Raybestos, I have to buy in large quantity. Anabond think comes from India. Pliobond was suggested as another good glue. I'll try to get you guys a good close up pic of the material.
    Does anyone on here have a source for new brake shoe springs only? Some of my old springs are :thumbsdown:
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is a close up of that Emergency brake material:
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I did both front and back sets on my 390. The new brake material is the cats ass!
    I had friends come out from Ohio and they go back to my Teenage racing years. We spent yesterday on our modern bikes having fun ripping bark off trees. So my friend has a 79 CR 390 stock and his runs perfect. He raced one back in day. I let him ride mine and he said mine is a monster over his.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I’ll post tomorrow how I realigned the shoes with pics.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I basically put old shoe in a vice and chipped old lining off with wood chisel. Didn't want to grind it off since might been asbestos?
    Then put shoe in blast cabinet and blasted old glue off. Then cleaned shoe with carb cleaner.
    Steve-F likes this.
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Put a coat of Pliobond on both surfaces (New Lining and Old Shoe).
    Baked in oven @ 200 Degrees just to dry Glue.
    Steve-F likes this.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Once dry. I used acetone to wipe on glue that is on old shoe to kinda re activate it. Then applied more glue to new lining and old shoe again. Line up the center marks I put on lining and shoe, then clamped them in a used hub.
    Bake @ 325 degrees for 30 mins.
    Steve-F likes this.
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    After cooled, I used my air grinders to cut excess off sides and chamfered both front and rear parts of lining (Like stock). Then cleaned up lining with 40 grit sand paper.[IMG][IMG]
    Bill502 and Steve-F like this.
  18. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Sweet!! Darin I used a different method and the WRONG glue, more of an epoxy and it did not squish out enough. I got everything apart and scraped the stuff before it set up. I made a circle with a pallet band and welded some small bent 45* pcs to a small turnbuckle and put it all inside the band, then adjusted the buckle out to tension the shoes to the lining. Looks like I'll be using your glue and my clamp system. Thanks for the R&D. How you doing that with the pics? Chris
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx DFA!
    I had to end up getting a Smugmug acct. for $55 year. I just upload to Smugmug, right click on the pic, select copy the image address, then paste in the pic tab on here.
    Wait till you use that Pliobond. It smells 100% like cat piss! Meow! Seems to be good stuff.
    With this new brake material. It bends real easy after heated, to dry 1st layer of glue.
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Next project, is to get this one finished off. Gonna send the frame out to get powder coated, since I had to rework the upper shock mounts to get the Fox shocks to mount.
    Steve-F likes this.
