Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Great Job. I may try this for my old Triumph which seems to be needing two feet to stop the darn thing.
    Bill
  2. Steve-F Husqvarna
    Vista,Ca.
    1975 Husqvarna 360 CR GP
    1965 Norton G15CS 750
    Bill
    " I can totally relate to this! 1965 Norton 750 ....1/4 mile lead time PLUS the 2 feet!!:cheers:
    Bill502 likes this.
  3. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Every time I look at one of your posts Darin I have to see bling bling !! What up!!
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Keep us posted how it turns out?
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Been like that ever since I was a kid. I enjoy doing it.......
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    DFA, You are slipping! You didn't notice the colored cables?
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Friend of Mine's 78 that I did engine for.
    Had to use two pipes to make one then blued it.
    Other than a leaky Karkoma (That I had to rebuild) She fired 3rd kick.
    Other than getting Oval Number plates mounted and set of chain and sprockets, this puppy is a done deal.
    Moto X Fox Husky frame is going to Powder coaters!
    [IMG][IMG][IMG]
    ct cr430 and Steve-F like this.
  8. Steve-F Husqvarna
    Vista,Ca.
    Really Nice!!:applause::cheers:
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx Steve!
    Steve-F likes this.
  10. Bill502 Husqvarna
    Upstate NY
    What paint did you use on the rims?Mine are in need of a paint job or getting Anadizing.
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    We never touched the rims since paint was fairly decent on them. Just elbow grease.
    I usually do all mine the anodized route in antique gold.
    Send rims to anodizer so he can strip rims and send back.
    Then sand and polish them.
    Send back to anodizer and they come out like new.
    On the tube side, I just bead blast area, then use soft wire wheel on a stand. You never see it anyways.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Bill,
    Another option might be?
    Use a coating on rims from KG Coatings (Gunkote).
    There are two colors Dull Brass or Pale Gold that might match up. I have Bright Brass in my inventory and would think it is too bright. Its the gold im spraying over the black on my cases.
    You might have to run a silver base under them? They could answer that.
    Basically, you just bead blast rims. Clean with acetone, Spray with Gunkote and bake @ 325 degrees for an hour. Stuff is bullet proof! It's all I use from now. Fuel proof, chip proof, etc....... Looks expensive but it goes a long way. I use an air brush from Harbor Freight to spray it on. I have a set of rims that are polished that I am going to add Gold and Black to. Rims are going on 125 some day.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Like to get this puppy fired by Monday!
    Going back together since I did final welding to modify the frame for Fox Shox and sent it to powder coater.
    Darn thing should rip since I ported it, made the snail pipe and still have yet to my carb mods.
    More Bling for you DFA!
    DeathFromAbove, ct cr430 and Steve-F like this.
  14. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Dang!!:busted: That is BLING BLING!!
    dartyppyt likes this.
  15. Justice Bikes Husqvarna
    Redmond, Oregon
    2007 TE610
    Several Classic Harleys
    [quote="dartyppyt,
    Nice job on that snail pipe, looks like an old "Baker" Pipe.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Got her fired last night, so just need to button some things up like, raising the front forks up some in triples, getting the rear shocks aired to my weight, packing the silencer, filling the forks, and machining few things.
    Anyone have some good jetting specs on the 82 CR 250?
    [IMG][IMG][IMG][IMG][IMG]
    Steve-F likes this.
  17. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Darin,
    Awesome
    What's she sound like? :popcorn: , i only seen the Snail pipe on Can-am's.
    Did you get any snow yet?
    Husky John
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx John and Justice Bikes!
    John, Sounds awesome but I had Gary send me jetting info. Lil Blubbery on bottom and previous guy had wrong Idle screw in carb. Plus I have to pack the silencer.
    I had two ziploc bags with 250 carb parts in them. One for 83 and one for 82. I cannot find one of the bags. So might of ended in trash can by accident. I do have the carb body, cap, float bowl, etc.... I have needles, slides, jets on there way, so that should clean things up with help of Gary's sheet he sent.
    No snow yet! Just that darn friggin wind! Gary was filling me in on some of your projects and racing accomplishments. WAY TO GO! Maybe towards spring I can give you some extra horses help?
    Thats why i wanted to build few snail pipes, cause it is a lost art. You are correct...... Can Ams, CZ's, Elsinores, YZ's etc...... Takes me about 25hours total to build one, with bike in front of me.
  19. ruwfo Administrator
    NJ
    Yes Gary, had a really nice running 250 , he built for our NY state friend Frank. My 83 250CR
    always ran sort of blubbery too, til i found the right silencer, it was a jaw dropper when i changed
    just that. I'm like how can a silencer clean it up that much :banghead:.
    2020 other the the Covid stuff, it was a good year MX Racing for me. Pick up my confidence & along with that my speed, it been along time since, i've really felt like that.
    So i've got Gary's juices flowing again (he's words) & the long semi dormant 1980 390CR refresh/rebuild started up last weekend.
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good Deal! Glad you are doing good race wise. Yeah, Gary is excited that you guys are doing the 390. Prob one of my favorites. Funny how just few pipe changes or silencers can make more performance. I don't know what is up next? Got 4 more to go. It's either the 82.5 500 or my 83 CR 250??????
