Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good questions Gary.
    I spent an hour in the anodizing plant in Indy with their foreman. Great guy!
    He told me what you get out of your prep is what your anodizing turns out like.
    He told me if to polish them so anodizing turns out the best. They send a lot of raw parts out to be polished before anodizing. I'm pretty sure that he said if I want them dull, not to polish them.
    I am taking mine down to a mirror finish. Maybe overkill but I do not want to redo them.
    I will to like 3000 grit and takes a lot less effort to polish on buffing wheel.
    He assures me that he can get close to the color. If memory serves me correct? Thought he said they add blue to darken gold? If memory is correct, I think they can also clear when done. Cause they kept saying that make sure I get old anodizing off and something about the clear being removed or it affects the new process?
    Funny thing is: some of my rims are brushed aluminum and some are not?
    I think I have a well preserved unfaded rim that I am taking to match the gold.
    I will find out soon. But also check as well. Two heads are better than one unless your are Siamese twins and your attached brother likes Pentons!
    I will run mine down right after thanksgiving and spend some time there.
    I have had a lot of auto parts done and was always told to polish them. I know they clean the aluminum and never had to worry about polish stuff down in holes to get out.
    Never have done the brushed affect on any parts.
    He gave me those sample color chips and they are shiney. The one antique gold one above matches my good original rim. Pretty darn close, match titch darker.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I just spoke to Mrs Wetzel think several months ago. Wanted to see if they had any jersey's around.
    She looked and did not have any left.
    They were good people and guys drove for miles to get their bikes and get stuff done.
    They were like another Hall's.
    justintendo likes this.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is the sample chip I have held up to my best rim.
    Pretty darn close if you take out the lighting hitting parts of the rim?
    Also, here is a pic showing those brushed aluminum marks under anodizing in some of my rims.
    Pic looks lighter because had to put it in light for brush marks to show up.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Going to try this combo on my 83 forks.
    Use a seal plus a modern fork wiper like newer bikes. Then go with short blue fork skins or like seal savers?
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Just love new wheel bearings with no grease ! Wth?
  6. oldbikedude Husqvarna
    Honey Brook Pa.
    At least this way you know they are greased right. Oh, not a fan of the looks of fork skins....but they do work.
  7. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i would prefer they came with no grease at all to be honest..would make it easier on my end.
    dartyppyt likes this.
  8. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Hmm, the longest part of changing bearings for me is washing the small excuse for grease out, and re-packing properly with waterproof stuff.
    There is a lot of work gone into those rims, they should turn out perfect.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys! I got some work ahead of me to get rims ready.
    Think I will get everything blasted up today then get my inside places done with a welding pass.
    Then got the holes to fill up in another rim where I had to drill and knock out the rim pins that snapped off.
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Fresh out of the paint gun.
    oldbikedude likes this.
  11. adam6402 Husqvarna
    Tulsa, OK
    None
    Damn, that sounds like a ton of work, but they are going to look great I'm sure! Looking forward to your continued progress on this herd of huskies.
  12. oldbikedude Husqvarna
    Honey Brook Pa.
    Tank looks like it was dipped in red......sweet!
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    These wipers do not work. These create air pressure between seal and wiper and hard to get in and when you push on fork, then one side pops out from air build up. Guess go back to the old way.
    I had to stick a feeler gauge between fork tube and wiper to get them in.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is front hub/brake plate on two fitty.
    Plating definately makes it stand out. Going to look good with forks.
  15. oldbikedude Husqvarna
    Honey Brook Pa.
  16. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    dang will those things ever see dirt?
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Troy,
    Ha! Not for a while. There is a lot of stuff I do behind the scenes that you guys don't see. Just the end results.
    Like on my front hubs. Here is finished one ready for etching primer versus one not done yet.
    Same on the back brake plates. I take out all those corroded pits using Evercoat, primer and spot putty. Plus, I put in all new bearings, seals, etc..... And if the back brake places are loose, I press in new bushings.
  18. oldbikedude Husqvarna
    Honey Brook Pa.
    Oh, many of us are oh so familiar with how much work, elbow grease, & patients it takes to get the results you do. I however am glad to see all the detailed steps you are showing us. Your builds are the ones I like following as much as any I've seen. You do nice work & are getting great results. You are going to have quite the collection of pristine Huskys. Hmmm, which one to ride first.......:popcorn:
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys!
    I think they will be worth it in the end.
    Tough doing all this cause I work like 50 hours a week, sometimes 60, and put about 70,000 miles a year on my truck traveling. Then I still race Harescrambles and we take care of 9 horses!
    Four Purty progressing and got forks done on 83 two fitty.
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is tank after I hand pinstriped it in white. Looking good!
