Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Ok my son was back at my shop last night with several of his riding buddies.
    We put my black 500 bottom end in and also the silver concept bottom end in.
    Everyone agreed that this took the cake. Nobody liked the black cases. Their Opinion is to do my rear spring, in the bright yellow tank colors. Paint my hubs in the silver with the blue rims. This is with my beed blasted 430 top end on, that needs sent out to be bored. But I have a twist to the top end, I think you will like. Just not done yet.
    Here is also a black cylinder I could do?
    grouty and oldbikedude like this.
  2. oldbikedude Husqvarna
    Honey Brook Pa.
    I'm convinced. Looks great. It's gonna be sweet.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx! Got lil worried there!
    But glad you and couple other guys give feed back! Sometimes feel like silence of lambs!
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    No worries.....just enjoying following your builds. Besides, these bikes are all you, for you. I have a hard time leaving or restoring any of my bikes to stock. I like to upgrade or "over restore". I got one bike that will be back to stock when I'm done...my Dad's '67 Honda dream.
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I agree totally. Most of them are going back to original, except for two.
    This 83 is one that when you wheel the thing out of the trailer, someone says: Wtf is that?
    The concept I am trying to pull off, is an 83 that looks more up to date modernish.
    The plan is to throw what I can at it.
    Head is going to look like an old Honda Cr porcupine head with a mohawk.
    Probably going to settle on polishing it.
    Pipe? I may build a cone pipe? Either gonna blue it or do it in nickel?
    Silencer is an Answer that I cut to make a shorty. It gets polished with maybe engraved Husky emblem.
    Cylinder gets ported and squished to run race gas.
    Air box gets polished.
    Might have guy make me an aluminum shifter tip anodized in blue.
    Swing arm is getting chromed.
    Rear sprocket gets anodized blue.
    Chain is a metallic blue one.
    I have an idea for a case saver that not only attaches to engine lugs but also the frame via two holes. It will get polished.
    I have an old fender brace that gets polished.
    All plastic and swing arm gets modern custom graphics.
    Cables prob silver.
    Carb hoses are bright blue.
    Rims are blue anodized and may do rim decals I silver and blue, with Husky logo's?
    Hubs? I polished front but think they will look better silver and logos highlighted yellow, like engine.
    I wanted to install a dry break system in fuel tank but there is not enough room.
    Sure wish I could find a kicker rubber in blue, but I do have a plan.
    So this kinda sums it up!
    Maybe 30 years down road. Some kid will try to reproduce it! Or after I'm gone, parts will show up somewhere and everyone will say that was Ol Typpy's bike! Ah, think I know who is going to end up with it!
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Next up for Auction is a new installed, then removed, 1983 CR 250 seat cover!
    I paid $60 for it. Yes I installed it then removed it. Still excellent condition but do try to line up my staple holes.
    It is very very good quality, with black piping.
    Here is deal! I will mail it to you, just reimburse me the postage fees.
    Like to find a good home for it, someone that truly needs it and will put it to good use!
    Pm me your address and it's on a first come first serve basis!
    I prob won't be able to mail it till after first year.
    SEAT COVER IS GONE!
    oldbikedude and justintendo like this.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Well if I get tired of building these pieces of Old worn out Iron!
    I have found a new use for them!
    Husqvarna Wind Chimes!
    They ping just like the cylinders do!
    oldbikedude likes this.
  8. adam6402 Husqvarna
    Tulsa, OK
    None
    Looks great so far, I really like the silver engine. Personally, I would have liked to see some non husky, sp onshore logos, pro circuit, bel-Ray, tire sponsor etc.
    You did exactly what I was thinking about with the shock bodies. What sort of plating is that, zinc, nickel?
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here are the hubs! Guess we just saved them from being Wind chimes!
    I am assuming that the hubs and brake plates are magnesium or some alloy. As soon as you polish them they tarnish right away. So that's why I shot them in urethane.
    I think they would be good wind chimes but I don't thinnnnnk Mrs Typpy would like them!
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    The shock tubes were brand new from Ohlins. I would guess by the looks, it is zinc.
    Ok you are 100 % correct. Did not think about all the sponsor logo stuff. So I will them in the front fender, rear fender and side plate graphics. Yep, your right, cause we had those stickers all over the bikes.
    I think that silver engine would look good in a Red Tank Husky with red detail or a Black and Silver tank Husky with black detail?
    Thanx on compliment!
    Gonna get up real early in morning and head to Indy to pick up all my rims.
    Going to drop rear sprocket off and magura levers for blue anodizing.
    When I get back, I can put front hub on and set the blue rim around it.
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is the blue metallic chain I'm going with.
  12. Husqvarna125 Husqvarna
    Illinois
    2014 TE250, 2015 TE200, 1984 WR 400
    Where is the blue chain from?
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Just google
    EK, 520 Metallic blue chain. There is place that has then in Tennessee.
    There is like a painted one, but those don't look good after few rides and cleaning.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Ok, back from Indy!
    Rims look pretty darn good. I am happy as heck! I can see some real faint stuff that nobody can ever tell. But I can look into a paint job and see flaws that no one ever notices.
    Around my welds, I need to try, a product called block heat. There is a real faint discoloration, but I have couple sets of originals that have that as well. Anodizer told me that if I can focus closer to weld area and control heat. Stuff comes out perfect. Ok lesson just learned. On the blue edges where tire gets covered up on the lip. It is real shiney and one lil area around a nipple hole. He said best thing to do is to send rims first so be stripped.
    Then bring them back to weld and polish. Then ship back.
    He said for all it's worth and labor using Easy Off, still not guaranteed. The shiney area is from old anodizing still in aluminum. But I got to say that versus what one Sun rim costs, versus what I paid for 8. It's hard to beat if you do some elbow grease!
    Here are the Silver, Gold Nordisk match, and the Blue!
    Also, wanted to show you the weld discoloration on the original rims as well. In the picture, you can clearly see the weld line. What doesn't show in pic, Is where heat from weld is discolored out slightly about 1/4 to 1/2 inch from weld. I would like to eliminate that, if I can block the heat.
    I also learned a trick. If rims are brushed, that hides it!
    That's prob why some original rims I have are brushed.
    I am going to do couple more sets, to see if i can get them 100 % perfect!
    Once I do that, I will list step by step instructions, to get perfect results.
    Ok, how bout some advice? You can see hubs and brake plates in same silver as engine. Do I do logos in the yellow or blue on the brake backing plates? That is all I am doing to hubs. Keep in mind, blue rims get stainless spokes and silver/ blue/ yellow Husqvarna rim decals.
    Dang blue rims is making that bike pop now!
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is color match versus a good original set. I say he is spot on with color.
    Starting from left to right. First two rims are new anodized. Third is good unfaded original rim.
    oldbikedude and grouty like this.
  16. oldbikedude Husqvarna
    Honey Brook Pa.
    Wow, they look great! Gold matches really well. I'd say blue on the backing plate logo. I think yellow might be lost, plus you already have the yellow logo on the lower leg. Just my 2 cents. No matter what you do she'll be bangin'.
    dartyppyt likes this.
  17. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Great match for the gold. Really I believe all your prep work and polishing made the real difference They look new!
  18. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    By the way Darin, do you have a paint code for the 82 430CR tank you shot? I want to finish mine over the winter.
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    That maroon color?
  20. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    they probably look better than new, you can see a lot of grind marks on original nordisk if you really look.
