Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys! Got sprockets from Spacely Sprockets. You know, where George Jetson works!
    No them PBI sprockets.
    Was hoping those Magura levers would anodize good. So was a test. I want to do some others now.
  2. oldbikedude Husqvarna
    Honey Brook Pa.
    You gonna look funny with blue fingers after your gloves get wet. :lol:
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Well my tongue turns blue from 7-11 Slurpees! So what's wrong with blue fingers!
    oldbikedude likes this.
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    you need a trim pussycat
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I do not have swing arm back from plater, to locate/fasten my rear mud flap. This gets attached to the air box I made. I can't finish it so I know where to permantly locate it.
    I'm gonna use a thin piece vinyl, used as a rub block on swing arm so it don't get all rubbed up.
    This is going to keep a lot of stuff off engine.
    Just wanted you to see it. I had to tape it on for now.
  6. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Cool stuff Darin!
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is new back modern fender.
    I have gone through a several trying to get them to fit the contour of the rear seat/cover. Plus be the right contour and land at the correct angle.
    The ones I all got all looked like they would work. But by the time you would need to trim excess off then they would be too short.
    Even the way this one is designed, it tapers in to the seat pan and looks like a factory fit.
    So landed one and hit pay dirt! Perfect and gives bike a sleek modern look.
    Thanx Steve!
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here are the good set of forks on there and not the spray can ones.
    everfree likes this.
  9. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    silver hub looks good. should be able to clean easier too
    dartyppyt likes this.
  10. adam6402 Husqvarna
    Tulsa, OK
    None
    Like this bike is ever going to see dirt/mud!
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    You know, just had that conversation yesterday with my son. Every fall they have a couple Team Harescrambles we race together as a Team. We always run the Father and Son Team. You can run any bike you want in the class as long as we switch off every lap. So I told him maybe we should run both 250's.
    I also have something to do on my bucket list. I'm going to load all the bikes up plus bring both our new Husky's.
    I have commitments from old friends, that we plan on a ride weekend. All we have to to is brush hog our old motocross track, as kids. Everything is still there. Jumps creek jumps, whoops, etc... There will be 6 of us, as we rode and raced as kids. Should be a fun weekend. But that is a plan/goal I have.
    husqyman, Greg Freiberg and troy deck like this.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    She looking beauuuuuuuuutttttttttttttiiiiiiiiiiiffffffffffffffffffuuuuuuuuuuuuullllllllll!
    It's a Husky! A Husky! I know it cause it says it on the bar pad!
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Worked this weekend on getting the right combination of fenders cut and fitted. Had one really look bad on rear, but by time I got it to fit seat pan, it was too short and wrong angle.
    Anyone interested in some cheap cut up fenders!
    Good that I can return the ones that weren't cut!
    Also, got bracket made and tapped into triples to mount the number plate. Lil frustrating trying to get new stuff to fit on the old, with the correct clearances, contours and angles.
    Got the forks all assembled.
    Hand guards are fitted and got the graphics on order for them.
    Now I am working on whole bike graphics. :thumbsup:
    Got the front fender, rear fender, number plate, etc.... Figured out.
    Think I have the graphics figure out for the side panels, as well.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Tonight, going to start working on some boot frame guards so don't rub all the paint off the frame:
    I have a couple of ideas for these.
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here couple more pics I just got chance to load:
    manu, oldbikedude and adam6402 like this.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here are my hand guard graphics.
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Blue or yellow Seal Savers?
    Black tire, blue rims, silver hubs, graphics in fender gonna be white, yellow and blue.
    Graphics are these colors I attached.
    Rear shock springs yellow:
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here are shocks for reference above.
  19. adam6402 Husqvarna
    Tulsa, OK
    None
    I like the blue seal savers. What make/source for the fenders?
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Fenders Are UFO brand.
    Rear is 04 Suzuki RM 125 Fender.
    Front is 14 Kawasaki KXF 250-450
    On the rear, there is a square area pre drilled hole, in the mounting area of Suzuki rear fender. It is used for an insert to be pressed in.
    You cut straight across fender. Side to side right behind this flat square area. The existing hole almost lines up.
    I use a piece of masking tape as a straight edge from side to side for my cut.
    Here is a photo illustration.
