Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. oldbikedude Husqvarna
    Honey Brook Pa.
    that didn't take long...lol
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here it is roughed in. Broke my smaller mill. So had to do the H lil bigger.
    Guess that happens when you rush too fast.
    darren7878 likes this.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Trying to do some tedious stuff to get hang of machine.
    Hardest part was using wench, then moving everything in place with pry bars and pipe.
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    Where there's a will there's a way. Leverage is your friend.
    dartyppyt likes this.
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    wow, that is totally ridiculous!! in a good way of course!
    Chayzed Pilot and dartyppyt like this.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yeah just some piddling to get use to machine.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is rough proto type.
    Going to beef up pivot joint some.
    Going to get a pointed mill to thin down the H in the center.
    But you get the concept.
    The final one will go on the 83 Cr 250 and tip gets anodized blue.
    Jens Ries likes this.
  8. oldbikedude Husqvarna
    Honey Brook Pa.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx OBD!
    Was only going to do one but now might do some for the other bikes.
  10. oldbikedude Husqvarna
    Honey Brook Pa.
    :thumbsup: Maybe some hidden checkering on the underside. Or should I say knurling?
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Top is knurled and bottom was as well. But machined into shape on bottom and sides removed it.
    But I can cut some grooves in bottom. Good point!
  12. oldbikedude Husqvarna
    Honey Brook Pa.
    That's what I thought might of happened.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I have a couple more designs in my head to try this weekend.
    Plus some neat other stuff in works.
  14. oldbikedude Husqvarna
    Honey Brook Pa.
  15. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    So what did you get for a mill? CNC or manual. I have a line on a Bridgeport J head that I will be picking up after my truck is finished
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I went with new Smithy combo unit.
    I was going to get everything seperate used. By the time I started chasing down parts/pieces missing, thought heck with it. Then ran into stuff 3 phase electric. Then looked at space to put it all. Then thought what is my limit on size of stuff to machine for bike stuff?
    I have not ruled out getting a CNC machine down the road?
    All my stuff is manual because I was concerned about digital reading stuff going bad.
    So far! Like it and think it works perfect for me and what I will be doing. I do have some adjustments here and there to tighten things up. I'm not going to do boring cylinders, but I did buy all the stuff. Mainly, just boring stuff and cutting internal grooves for o rings etc...
    Still have a wish list of items to look for: rotating mill table, face plate, step blocks, v blocks, etc...
    I have not realized all the stuff that I have forgotten over the years, but it is coming back.
    Biggest thing is I need to have patience!
    Bridgeport is nice if you can snag it!
    What is sad is that all this stuff, is becoming china farmed out!
    Old barn beams were bowing tho! Wasn't sure I could get moved into position rolling on pipe, crow bars etc....
    However, I either messed back of my knee up or tore all muscles in back of my calf!!!
    Almost, thought of just putting layer of crushed ice down and then when machine was in place. Just letting it melt into the spot! That's how I set/move big granite monuments/mausoleum buildings. Ice and cranes. Ice lil more difficult in winter!
    Here you go Jim!
  17. jimspac Husqvarna
    Connecticut
    You got a great one there. The J heads with the cast door on the side of the main casting has amongst the best machine iron that was ever available. Treasure that baby! My old Series II NC ran better at 35 degrees than it did in warmer seasons. You just need to put them under a tent when the humidity condenses and it would look like you had a rain storm in your building. Save desiccant packs to put in a tray on your table when covered. The machine I will be getting has a 32" table but considering the guy treasures my advice he is giving to me. I just have to move it.
    oldbikedude likes this.
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    All my stuff showed up so should be some good pics to post by Sunday night!
    As long as I don't get rammy and break mills!
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is my 83 250 gas cap I made today.
    Eventually, I will have it blue anodized.
    But you can see what it looks like.
    loony888, oldbikedude and justintendo like this.
  20. justintendo klotz super techniplate junkie
    the knurling is a nice touch
