Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Now you know why there is a headless horseman running around.
    Study the last pic!
    Going to make parts for another one and this will be a shorty one. It is going to go on the 390 with CR ignition. Should open the top end up some on it.
    I should get the tubing Monday night. Then all I have to do is assemble it.
    justintendo likes this.
  2. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    I found that my regulator(Harbor Freight)on the TIG lost a diaphragm so that was why mine emptied so fast
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yeah something goofy going on with it. Happen when I hooked new bottle up.
    Needle was under the post, so not sure if it just blew all around the whole gauge?
    Hopefully, going to pull the one off my mig to see if it will get me by this weekend.
    I have no idea where my gas is at, but I can tell welding.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Next silencer in works.
  5. oldbikedude Husqvarna
    Honey Brook Pa.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx,
    Should have all the pieces fabbed up today and get them polished.
    The tubing should be here Monday, to fit all the pieces together in it.
    As long as I don't screw the back end cap up today milling it.
    The back cap is going to be two pieces. I will prob cut an o ring groove so it doesn't weep spooge.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    All I need now is my outer tube and looks like a done deal.
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    If you want to make perfect baffle.
    Get what ever size tube that you want inside diameter to be.
    Roll it around tube best you can. Then put 4 hose clamps on it and just tighten them enough so you can pull tube out.
    Then spot braze it down seam and keep moving your hose clamps.
    Start in center and work your way to ends.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    So far
    oldbikedude and justintendo like this.
  10. dingodog Husqvarna
    The Garden State, Au
    '73 CR125, '82 WR250,
    XC150
    Hi there. Could you please outline how you painted your fuel tank, like stage by stage? I am interested in how many coats you applied to get such a great finnish, decals under the clear top coat, just one top/clear coat? Many Thanks.
    troy deck likes this.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    if the space shuttle ever needs a muffler, your the man for the job no doubt!
  12. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    not sure if we wana go there that could be a whole other:eek: thread
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Final version of shifter tip.
  14. eddychecker Husqvarna
    Sycamore, IL
    2011 TCX250 & 2013 TE300
    2008 KTM 450XCW
    Excellent work as usual.
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx bud! Here is wat the big gun will look like without bracket.
    Just a sneak peak!
  16. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the silencer looks seriously nice. really as good as anything aftermarket
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanks! Wait till you see the other one!
    Damn my shop sure is using a lot of coal!
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    got the furnace humming no doubt
  19. oldbikedude Husqvarna
    Honey Brook Pa.
    What about the "midnight oil"? :D
  20. MarkVMod0 Husqvarna
    72 CR450
    Honda CBX's,BMW K1600GTS
    Keep burning that coal....my stock in Peabody tanked thanks to POTUS and the EPA!
