Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Shox came for Maico with cracked hubby!
    These are the older ones and I'm sure they will perform half! But they will look good!
    I will rebuild these and shorten them some.
  2. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Please beware and make sure these are not 82 Maico hubs. These are the one that cracked and led to the downfall
    of Maico. It was a combo of extreme shock ratio and bad hubs that folks got hurt. And sued. Some were more than hurt.
    Let me check on prices newly made cnc hubs by my friends in Germany. All newly made.
    ajcmbrown likes this.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I'm getting Maicoeducated...... Gary, this rear is the stock, cast magnesium 79 hub. So yes, I'm looking for a new rear hub.
    There are some out there for 169ish to 249ish dollars. I can get a new aluminum one for like 290 BP. So, yes rather just go new and then I know what I got. I should not have an issue with the front. I do like the 250 powerband...... I still want to do some modern mods to the carb to get more bottom out of it.
  4. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Thinking Mikuni or Lectron?
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I'm staying with Mikuni but doing my modern mods in them. If it works? It should....
    If not then few of them that will be riders, can go Lectron.
    Bunch of these will run good but be stored away. I'd like to donate a few after I'm gone to maybe ama museum in my name?
    Oh and just for kicks? One of those Husky ol Conical hubs, looks like it would go right on the Maico. Have to modify the spacers a lil and possibly the brake mount and plate.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    This is like the Field Of Dreams! If You Build It, They Will Come !!!
    Now This Is The Shop Of Dream! If You Build Them, They Will Run :) !!!
    oldbikedude likes this.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    This is Frick and Frack!
    But Don't Kick Back !
  8. jimspac Husqvarna
    Connecticut
    Mine is The Shop of Misfit Toys
    Once fine machines cast off by indifferent boys
    While each has it's own story
    They all dream of returning to their former glory.
    dartyppyt likes this.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    New rubber and new spokes......
    Only 71 more to polish! Ugggggg!
  10. cruisetopdown Husqvarna
    VA
    1982 and 1983 Husqvarna 250 XC's
    You can donate them to the "Cruisetopdown" museum :D
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Ha! Funny! Don't you have some restorations you need to work on? Like your own Silver dollar project?
    Mine are just a huge money pit that keeps growing like a sink hole, that consumes a house!
    Guess my 250,390 and 500 cylinders are done. Guess through conversation with Jay at Halls, they put the decompression buttons in the heads of 430,390 and 500. Install was $50 each so not worth me doing it.
    The other two have pistons coming.
    markt2 and cruisetopdown like this.
  12. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    nice, but you shouldnt be revealing your secret piston porting mods!
    dartyppyt and oldbikedude like this.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Since it was Halloween!
    Figured I'd post those Wossnster pistons! Muwahaha !
  14. GaryM Husqvarna
    Austin, Tx
    1981 490 Maico
    Now if your in garage long enongh , those pistons will start talkin to you. If yu dont
    talk back to them you will haunted by seizures for years !!
  15. oldbikedude Husqvarna
    Honey Brook Pa.
    Better talk nice to them.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Progress
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Fox bike, with gold rim but it need a tube!
    Not you tube! Motee sickle tube!
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    progress in da shed
  19. cruisetopdown Husqvarna
    VA
    I love that Moto X Fox Bike! You Da Man!
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx! I looked all over the internet to see if someone ever did one? I couldn't find one, so thought? Hell, I'll build one!
    It's really growing on me...... Glad you guys pushed me to the bright gold rims! I was set on black but they make it pop!
    I'm pretty darn good at lacing up and truing rims but these Akront dimpled rims were a bear. The nipples didn't have much clearance in the holes. I prob should have drilled them out lil. The spokes might of been a slight bit longer as well? I tried every technique imaginable to make it go fast.In order to get the nipples started, you had to make sure the spoke and angle were aligned.I would be on one side and see a bunch of nipples that fell out on other side? There were tons of swear words. Rear took 8 hours. Front took 2 hours! I did not want to scratch them! It was messing with my mind. I usually just stick spokes in both sides of hub and get my pattern down and fly. Now the other bike, with Nordisk took about 45 mins each with truing.
