MotoZ tires 200 mile report...
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Motosportz, Nov 10, 2008.
  1. BtodaB Husqvarna
    Pa
    Tire sizing
    Should I go smaller, Do you have the next size down? 120/90/18
    Is that small enough?
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Kelly was running a 140 on his 450, so I'd think the 130 is the correct width for your 250 class bike. I'll let him give the final verdict though.
    My little report.....
    I mounted up a set of the Enduro S/T's (is that the Tractionator!?) on my WR300 just before New Years so I could have some fresh rubber for the annual Hangover race, which is always a brutal mud fest. I set the pressure at 6r-7fpsi and they freaking ROCKED! The studded tire guys were at an advantage in sloppy corners and log sections, but straight line acceleration and braking I was able to hang really well. They did phenomenal and looked brand new when the race was over.
    Next few rides were in the local mtns. Lots of rocks, roots, clay-mud and water. They did not disappoint here either. I was a little worried about using a soft terrain tire in the rocks, but they gobbled it up and never felt sketchy and did not wear out like I expected them too.
    Last ride was out in the desert. Loose sand, lots of ice/snow (this time of year), LOTS of sharp volcanic rock and plenty of downed timber to smash them into. I ran the pressure at 10psi front and rear for protection from the volco-rocks and they absolutely were the most confidence inspiring tire I've ever used there. Just stuck like velcro to everything..... well, the ice was still problematic, but nothing is perfect. I smashed into rocks, logs, sharp edge acceleration bumps, friends, friends bikes and whatever else happened to lay in front of me and never once felt my rims take a hit.
    I'm not a tire connoisseur and I usually buy whatever happens to be the best bang-for-the-buck at that time, but these tires were different. I actually felt the improvement after mounting these to replace the stock front and rear Bridgestone 403 I had previously mounted. For comparisons sake, I just mounted a set of Bridgestone 403/404 to my Yamaha and went woods riding. The rear skated in corners and left me with no confidence in their ability to hold a line in the rocks and moist soil. Some of this surely has to do with the aggressive power delivery of the YZ vs. the soft delivery of the WR, but that's only a small equation. The Motoz stick to that ground like a tire should.
    I think they're the best thing going. Especially since last time I was in the shop ONE rear Dunlop cost $90 and those suckers only last a handful of rides. I've got about 6-7 good rides on the Motoz and the front look immaculate and the rear has only just begun to lose its edge and I do not try to save tires. I consider them a high wear item and I abuse them accordingly.
    I was somewhat skeptical of all the raving reviews, but I talked to a few friends of mine whose opinion I trust and they both swore these tires are the real deal. I'm glad I listened! I can't guarantee everyone will gel with these tires as well as I did, but they work in my terrain and work with my riding style perfectly. I'm sold.
  3. Motosportz CH Sponsor
    Nice report Brandon. thanks.
    The Tractioator Enduro S/T are very good loam / loose condition off road tires. Actually cross over well into IT terrain and are always predictable.
    The Terrapacor's are the lighter weight more MX versions of the Motoz and are fast becoming my favorite for the light bikes like my 125. Rode in slick clay with these on my 125 and giggling while motoring bu people. Awesome stuff.
    Motoz IMHO...
    - Excellent practicability
    - great traction in a large variety of terrains
    - Last a long time
    - hook up great even when well used
  4. BtodaB Husqvarna
    Pa
    tire size
    That was my bad. I have the TRACTIONATOR® X-CIRCUIT on my 310. It is a 130/90/18. We put one on my friends KLX400 and it fit but looked pretty big. I am woried that it still might be too much for the 310. Does anone know for sure?
  5. ghte Husqvarna
    Bright, Victoria Australia
    Worst thing to do is over tyre a small bore. It will rob power and make turning harder, also known to wear clutches fast and cause overheating. I would swap it out for a 110 or 120 max.
  6. Taz Dude Husqvarna
    San Diego
    I have Tractionator H/T on a 610 and I weigh 280 without gear so i'm easily over 600 lbs with gear. I've ridden in many different conditions now including about 6 inches of fresh snow. These tires are just awesome!
    I have followed other bikes on Pirelli Scorpions and D 606 and watched their bikes all over the place, while my bike stayed straight and on track.
  7. Fema Husqvarna
    Finland
    Wr125 2011
    a scooter :3
    ^ I just hate Pirelli scorpions, those tires lose their knobs on my first ride on the trail, waste of money I say... are these motoz' any better? there seems to be a dealer here in finland:banana: considering buying these as my next set :cool:
  8. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    What pressures are people running? I have the Tractionator IT at 12r psi and 13f psi but have gotten 2 pinch flats on the front. At these pressures the tires bounce aroung a little compared to the x-circuit I ran.
  9. Motosportz CH Sponsor
    i run 10-12 and not had any issues with the IT front. :excuseme:
  10. Indorider Husqvarna
    Bojonegoro, East Java Indonesia
    2010 TE 250
    Yamaha TZM, Suzuki RGR (2 smokers)
    Couldn't have said it better myself. A bit like this dude (unfortunately a lot of their women look like the dude(?) on back)...:cheers:
  11. fasteer Husqvarna
    Calgary, Alberta
    2017 701 Enduro
    Sherco SEF300 (for sale)
    Kelly,
    TE511 for mostly off-road dual sport in Rocky Mountains: dirt, rock, roots, not much mud, no sand.
    Tractionator Enduro I/T ?
    130/90-18 ?
  12. ghte Husqvarna
    The thing I like about Motoz is that they are a great Aussie product.
  13. Weantright Husqvarna
    Burton, Oh
    I like and have had better luck with the X-circuit. The I/T dont hold traction like the X-circuit and the front needs 10-12psi to stop bouncing off rocks. This makes flats quick! X-circuit I can run the same psi without flats and even go higher without the tire bouncing. Bike is a 2010 TE310, went to Tubliss system to stop flats.
  14. Connor Husqvarna
    Maryland
    '12 TXC310
    How do these work on the East Coast? Specifically Like in the states of PA,MD and WV. I run a Pirelli MT16 on the rear with a Dunlop MX51 on the front. Run about 10PSi in the rear with ultra heavy duty tubes and haven't had a problem yet. The MT16's wear like iron and have amazing traction all over. Has anybody tried the MT16 compared to these?
  15. Weantright Husqvarna
    Burton, Oh
    I like the motoz tires over all others I tried. Good consistant traction all the way down to 1/4" knobby. This is in Ohio and PA rocks, woods and road. Necer tried MT16 and the MX51 on my son's bike are wearing quick.
  16. Motosportz CH Sponsor
    I guess it is the area you ride. I like the IT's (love the front one) better than the X-cir. All good. the HT rear is fantastic as well.
  17. Weantright Husqvarna
    Burton, Oh
    Not as much as the area but personal preference like handlebars. PM me info on nomad tank for my 310.
  18. Connor Husqvarna
    Maryland
    '12 TXC310
    Well I've heard some good and some bad about these tires. But over all they sound like a nice tire. Ive tried the MT16, the Dunlop MX51, and the Mitchelin M12 and S12 and so far ive had the best luck with the MT16, however, I am considering trying something new this time (just outta curiosity). Maybe a motoz is in my future, who knows :thinking:
  19. Motosportz CH Sponsor
    Tires are highly subjective tot he user. Use what works for you. :thumbsup:
  20. Connor Husqvarna
    Maryland
    '12 TXC310
    True true true. I saw that Andrew Delong has been running the maxxis tires, not sure if it's the SI's or the IT's, does any body have any thoughts on those?
