What is the 165 like as a Motocross engine. As I ride MX tracks a lot and have one in my back yard.[/URL][/IMG]
[/URL][/IMG]![]()
I think it would be expensive to buy a complete CR ignition. I have not fitted the 144 kit yet. I want to learn how to ride it as a 125 first and put some hours on it then fit the 144 kit. With the possibility of using the 125 parts to send away for the 165 kit. To fit sometime well into the future. (Undecided at the moment.) I am enjoying it as a 125 so far.Get the cr ignition and leave it as a 144 for mx.
Does a 165 run with the 125s or 250s in mx?
I just got the word that a 2s 165 would indeed run with 250 4s. I can well imagine it would be a smokeathon against those pigs with Walts kit. 150cc is the limit for a strictly 125 class.
Hi Head,
We have two XC's here a XC 125 with a 165 kit and 144 kitted as standard Xc that was post GFC stock that PFG bought in and sold at very good prices.
Make sure before you pretty much do any riding that you take everything apart and grease everything, that is swingarm bearings, control linkage, head stem, and even the axle shafts (thin smear of grease and well oiled), you will most likely also need the front axle nut changed from the large allen key. Just a note, the 2010 WR's came with a softer spring than the XC's (o.42 kg cf to 0.44 kg) and rear's are the same at 5.0kg. We have had ours all revalved with new seals (SKF's) so unsure what yours is sprung like.
They are a brilliant little bike, and so fun to ride (coming from a 250 EXC KTM).
