Need help with carb
a clean muffler is important.
you can stick an oxy flame up the muffler inlet and cook the crap out of it which will burn out all the carbon, oil and grease etc that has built up.. you can build a good bonfire and chuck in that and get it red hot. you can also soak in a drum of solvent but that takes a long time and can be real messy and only removes the spoogy crap not the carbon build up
if you oxy it you need to be careful you don't melt the inlet end if it gets too hot. this process can set up a "jet engine" effect with a nice afterburn coming out the end which is good. ash and crap will go everywhere especially over the freshly hung out washing... the smell will carry for three blocks and some one may panic and call the fire brigade.
if you cook it, once its red hot you need to tap and bang it with a bit of wood to knock the carbon out but not dint the crap out of it.
have fun
Talked to John at Vintage Husky, he said since the only problem is top end and leaning it out that much does not change results that it is probly the motoplate breaking down. He said to check the connectors at the coil to make sure there tight as they will cause that too, but they were tight. I cleaned them reinstalled. will give it a try but I'm not confident that was the problem. Will have to get another ign.
Run a ground wire from the motoplat mount up to the coil mounting bolt.. Sometimes they don't ground good.
i have 4 of them just sayin :thumbsup:
DPete did you figure out your problem with the 360WR? I replaced the ign. with a MZB. But still have topout problem. It is a lot better but not 100%. I went back to my original jetting setup but same going to try cleaning the exhaust out with bondfire and seeif that works.
You might as well roast the pipe along with the silencer.
Didn't have to roast exhaust. Went done 1 MJ size and warmed it up good and it came alive. Brings the front end up in first three gears at will, I'm 60 yrs. young and 50 lbs. over weight so that is good for me. For anyone else on here with a 360WR here is what I'm running.
I have a 1976 360WR with a 38mm (measures 37.68mm) Mikuni VM carb. Here is what's in it
Main Jet 360
Pilot 45
Needle Jet Q8
Jet Needle 6DH3
Slide 2.0
Air 2.0
A new MZB ign. timed at 3.02mm BFTDC. Starts great and runs great. Thanks to everyone for the help getting me there.
