new goodies - bar pad, exhaust plug, hi-pro water pump...
Discussion in 'Motosportz' started by Motosportz, Jun 16, 2010.
  1. motosportz mike CH Sponsor
    Washington state
    1. The 2010 hard parts catalog lists it as fitting
    2. sorry, no pair.
    3. I can not find any huskys with it stock, it is even an option for the SMRR
    4. yes all models
    5. 39.95
    6. sorry we sold out of the water pump on monday, we have more coming in a little while.
  2. Motosportz CH Sponsor
    Note - Water pumps are out of stock. We only had a small pile which is why we just announced it here instead of adding to the web.
  3. MXRider Husqvarna
    Virginia
    None
    2009 Yamaha YZ250F
    getting any more pumps in the near future?
  4. Motosportz CH Sponsor
    Yes, we have some on the way. :thumbsup:
  5. MXRider Husqvarna
    Virginia
    None
    2009 Yamaha YZ250F
    very good, how about the uptite y pipe?
  6. Motosportz CH Sponsor
    Might try George, we are waiting for more.
    K
  7. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I hope to be on the waiting list for one:thumbsup:
  8. Motosportz CH Sponsor
    you are. We got a pile of the red oil fill plugs in too. :thumbsup:
  9. HUSKYnXJnWI Husqvarna
    09TE450
    Thanks Kelly- sorry for delay on my part- I have too many emails to look at sometimes. Paypal order completed. Send whenever you get em':cheers:
  10. bandkw Husqvarna
    Minnesota
    I just finished a four day trip of trail maintence and riding. Not sure which part is most responsible, but this is the first time since early this spring that my 2009 TXC has not boiled over and come home needing repairs.
    Before this trip, I added the high flow water pump from this thread - not sure why it isn't stock, I added a TE fan with a manual switch to turn it on - the 12V switch was about $4 at a local tractor supply store, and I switched to waterless coolant from Evans that has a boiling point 100 degrees F above engine ice for about the same price as engine ice - a little bit more with delivery charges.
    My last race, the engine got up to about 260 degrees, cracked the radiator and blew out all of the engine ice (not positive which happened first). This weekend, riding through very similar trails with air temperatures about 10 degrees warmer, I got the engine up to 204 degrees one time, then turned the fan on and cooled it down to about 180 pretty quickly. On more open trails, the temperature varied from a low of 146 with the fan on to a high of 172 with the fan off most of the time.
    Again, I don't know which of the three is most responsible, but I do believe my Husky has finally become a dependable bike that I can again look forward to riding.
    Thanks Kelly!!!
  11. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    How are you measuring the engine temp? A strip or a infrared device or ?
  12. Motosportz CH Sponsor
    I'm guessing with a trailtech or something.
    Good stuff, thanks for sharing.
  13. bandkw Husqvarna
    Minnesota
    Ahhh, should have included that information. Trailtech Vapor computer with the heat sensor in the hot water hose coming out of the engine.
  14. KCI-John Husqvarna
    Austin, TX.
    Bandkw,
    This "Evans" stuff sounds good, tell us a little more! Where did you get it(found it at Amazon for $34 a gallon) and which one did you decide on, the NPG-R? Thank you!:thumbsup:
  15. bandkw Husqvarna
    Minnesota
    I purchased the 1/2 gallon SF+ from Zip-ty racings web-site. I picked it because they did not mention needing to flush the system with a second $30 bottle of fluid to get rid of all the water before adding the waterless coolant.
    When it came, I discovered two things:
    1) they say the water content should be less than 5%, preferably around 1%. In other words, drain all of the original coolant you can, then dump our stuff in there.
    2) there is an Evans logo on the front of the bottle, and I'm pretty sure it is the same stuff that Evans sells. Not sure if it is the NPG-R. It is pretty much the same price, so I don't see any real reason to buy from one place over the other unless one is closer to your house so it arrives faster or you need to purchase a second product for one of them.
    I bought the 1/2 gallon size because about 3/4 of a 1/2 gallon bottle fills my Husky radiators and reservior (which I learned by boiling the radiator dry a couple times and re-filling with $19 per half gallon engine ice). My real hope it to not have any additional boil over issues, and to keep the 1/8th gallon of waterless coolant on my shelf for years to come.
    It has been 80 to 90 degree F highs since I received the bottle and opened it. The liquid looks like water when you pour it but has kind of an maple scent to it.
    Anything else I can describe?
  16. rbeto Husqvarna
    450sm 2004
    Hey guys, my name is Roberto and I have a husqvarna 450sm 2004 and want to put the hi-flow water pump to my bike, but the local dealer told me that it only fits together with the 2008 models, do you know if it fits together in 2004?
    number of the high flow pump is this 8000H2449
    Thanks, greetings from Mexico.
