No low fuel indication
Discussion in '4 Stroke' started by apnea, Apr 6, 2010.
  1. xymotic Husqvarna
    Federal Way, WA
    T.M.I.
    Way T. M.:lol:
  2. CARL REHATCHEK Husqvarna
    Tamaqua, Pa
    2010 TE 250
    Well seeing the amount of only the surfers here it is more then a one and done .. but if you call the dealer for a replacement part and not what does the bike warranty has to offer I could only figure what the dealer would say... It is in the Husqvarna book on how to deal with items that are showing a possible situation consistant with others of the same condition.
    I know alot of riders want to fix it and get riding but it doesn't help if the compnay is not seeing a light going on.. They need reporting and how items were fixed to help others rider know of the what if this happens and how to get going again..just a thought..
    Chow, Carl
  3. jlk_250 Husqvarna
    Minneapolis, MN
    That's a different problem, the "slipping fuel pump", which is caused by the cable tie that secures the fuel pump in place swelling and letting the fuel pump move up out of position and suck air when the tank gets low. Search and you'll find threads with pictures of the problem and the fix. (Don't fix it by tightening or adding another cable tie in the stock location. Won't work long term if you do that.)
  4. jlk_250 Husqvarna
    Minneapolis, MN
    Interesting. This looks like either a newer or an older design than what I have seen before. Other ones I've seen have an orange ground wire soldered on where the sensor body attaches to the bracket, and the bracket looks different. Some of those more common ones have broken the orange wire off at the solder joint, or broken the solder joint attaching the body, or broken the bracket itself, but in a different spot than yours. So both designs are flawed, apparently, regardless of which is newer.
    Here's a link to a thread with a pic of the other version I refer to.
    http://www.cafehusky.com/forums/showthread.php?t=1442&highlight=fuel pump pictures
    You could quick and dirty fix it by soldering the ground wire on like the other design and cable tying it in roughly the right spot.
  5. racedesert_ Husqvarna
    Henderson
    My 09 TE 450 just shut down. No fuel pump prime. Pulled the pump to find my low fuel sensor hang by only the wires and my ground wire to the pump pulled off. Repaired ground wire for the pump and ty-wired and zip-tying the sensor back on the shaft.
