Noisy rear disc brake
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by 09Husky310, Mar 11, 2012.
  1. Tetley Husqvarna
    UK
    I thought about squeezing the mounting washers slightly until they grip the disc. This way the disc can still move when it heats up, but will not be able to rattle. I hope! I shall give it a try, and report back.
    My mates RM 250 has a floating front disc, but it has spring wave washers in the grooves to stop it rattling.
  2. Tetley Husqvarna
    UK
    Sorted the problem permanently.
    I fitted a disc from a TE 449/511. It bolts straight on, although you do have to use the 449/510 bolts. No more rattling for ever!
    Just did the Welsh 2 day enduro, and it performed faultlessly.
  3. mkfox Husqvarna
    Michigan
    2002 WR250
    1973 Greeves Griffon
    Got a solid mount rear disc from Mike at MotosportzHusqvarna for my 02 WR. Maybe available for the newer ones too? Do not have to listen to the rattle any longer.
  4. shilo020 Husqvarna
    Redlands, CA
    TE310 2010
    ZipTy changed mine to solid mount. No more rattle.
  5. ghte Husqvarna
    Bright, Victoria Australia
    I had noisy front and rear brakes quite a while back. I took out the pads, gave them a light rub with a brass wire brush (took of the glaze). I now give the brakes a squirt with brake cleaner after every ride (post wash) and no issues since.
    268fords likes this.
  6. Husky450AUS Husqvarna
    Queensland Australia
    2009 Te450
    Good to see I wasn't the only one concerned about this when I first got the Husky..........don't really think about it now though :excuseme: .
  7. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    My front does the hot howl too. I figured it's just glazed, but I'm too lazy to mess with it. I'll be needing a new front tire soon, so while it's off, I'll hit the rotor and pads with the ol Scotch Brite. I think it sounds like a dolphin in heat sometimes. :eek:
    BILLF and duggoey like this.
  8. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I look at it as. If I'm thinking about or listening to the rear brake I'm not going fast enough.
    I don't find it annoying, but who knows maybe if I throw some o-rings in there I'd be suprised.
    BILLF and HUSKYnXJnWI like this.
  9. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    My rear brake only rattles in my driveway or in a pit area... as far as I can tell.
    BILLF and jmetteer like this.
  10. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    It's a good idea to remove your rear disc and clean and re secure the mounting bolts. While your reinstalling, that's when you put some silicone inside the holes. I did mine two years ago and they still are holding and not rattling around. Pulling the pads after every ride is so easy to do.
    BILLF likes this.
  11. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    My rear brake finally stopped rattling....after the disc got bent by a big rock...oscillates a little when braking but otherwise, works fine...
  12. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Funny, I just bent my front rotor this weekend and it's like having ABS. Pulsating caliper. Rear is still quiet.
  13. panhandlebars Husqvarna
    Hayden, Idaho
    '11 wr 300
    ktm200sold!klx125&drz 70 kids
    Funny thing when I had a decibel test at a trail head I was high but then when I stepped I the brake and quit the rotor rattle it dropped 2db ...if I remember it was 98db to 96db . Wr 300 with a spooged Leo Vince in need of a repack...stupid rotor rattle bugs me ...worse than vw pea shooter exhaust on a bug...nails on a chalk board...how do you solid mount?
  14. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Since my rear rotor is probably past the wear limit, I need a new one and I want a solid mount, so I am interested in hearing what will fit, doesn't need to be wave, just that it fits the mounting holes.
    panhandlebars likes this.
  15. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    Mine stopped rattling too thanks to a rock :lol:
  16. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    racediscs in the UK & Zip Ty. do a search, threads about em on here:thumbsup:
  17. Boogie Husqvarna
    Australia
    Red head
  18. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Wow, it's clear to me now, thanks for posting that, I was in the dark.
    Boogie likes this.
  19. Boogie Husqvarna
    Australia
    Red head
    IMHO The full floating rotor is the superior design. There is less brake drag, less heat transfer between rotor and hub, less warpage from heat as the rotor is not fixed at any point thus allowing it to expand and contract freely.
    Your rotor will keep cooler and brakes will work better for longer. Your hub will keep cooler and your wheel bearing will last longer. Etc etc
    The noise is the only downfall.
  20. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Cleaning and lubing the mounting pins and seals that the caliper slides on should be a regular maintainence point. When they get crusty the caliper can't center which contributes to drag and more noise from the sliding type rotors.
    The 2002 and earlier factory solid mount rotor and bolts will replace the later (small) rear sliding rotor, bolts and spacers..
