Nomad add on tanks... We have them
Discussion in 'Motosportz' started by Motosportz, Jun 25, 2012.
  1. Desertyucca Husqvarna
    Yucca Valley, CA
    TE 511 & TE 310
    DR650, IT490 a few others.
    Kelly,
    I road around Johnson Valley with the Nomad tank on the 511, 40 miles of desert 2-4 foot whoops and the tank held its place nicely! The first few miles, the weight change took a little getting use to! :eek:
    Tank Worked Great. I might be ready for a 90+ Mile dual sport run now! :popcorn:
    Thanks Ken
  2. Motosportz CH Sponsor
    Very cool. Thanks for the report. Mine has been rock solid as well and i have abused it.
  3. BiG DoM Husqvarna
    Is ot OK to connect this tank into the crossover tube between the two tank lobes? Would one then need to use the main tank first and then open the bumtank to siphon through? Just trying to get my head around this. Presumably if both were full and bumtank was open it would want to push gas out the main tank?
  4. Motosportz CH Sponsor
    Yes, the Nomad is above the main tank and drains into it. Works great but you have to make sure your main tank cap is good or it will leak. I went to the aluminum aftermarket one and it solved the issue with my leaking stock tank cap and zero issues. I did install at petcock to i can stop the draining if I need to.
  5. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    Can you pm me a price of a tank for my TE310? Also if you have pictures on the installation.
  6. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    I am planning on ordering one of these my next payday for my wr300. We have a bend trip coming up and are taliking 70 mile routes. My only question is if i mount it to rear fender would it interupt the signal of my trailteck gps antennae?(i have it mounted on the rear fender). I was thinking of moving it anyway so this might provide the motivation for my lazy butt.-lol
  7. Motosportz CH Sponsor
    If it covers the antenna yes. I have several option here for your bike. Let me know and we can sort out the best option for you. You are more than welcome to come down and test fit a few of them and see what you like.
  8. jon6.0 Husqvarna
    Phoenix
    2011 TE449
    2009 Triumph Speed Triple
    Will any of the larger tanks work on the TE449?
  9. Weantright Husqvarna
    Burton, Oh
    I still cannot see how these tanks will work on my 2010 TE310. Can anyone send me pictures or details on how this is done??
  10. Motosportz CH Sponsor
    You need to see the beginning of this thread
  11. Weantright Husqvarna
    Burton, Oh
    ONLY way this will work on my 2010 TE310 is if I unbolted and dumped the fuel in or syphon the gas from tank to tank via cap vents. I have no cross over tube, only one line coming out of the tank to the injector. Now I can read the beginning many more times but without picture of the "tie in" or an explanation better than "it ties in" it will not work! My bike might be a one of a kind without a cross over tube so please explain better how to tap in.
  12. Motosportz CH Sponsor
    Is there no external low pressure fuel lines anywhere on that bike?
    - the tank is held on with straps, it would be EZ to unstrap and pour in but far from ideal obviously.
  13. ST Rich Husqvarna
  14. Fast1 Husqvarna
    Minneapolis, MN
    Are the dimensions available for the 1.5 gl and 2 gl product?
  15. Weantright Husqvarna
    Burton, Oh
    No low pressure hose anywhere. Like I said just one hose coming out of the tank. Only other item is the wiring harness. Might need to update "these don't work for the TE310 bikes"
    ST Rich, might need that spoon because when I contacted them the reply was it just ties in, use the "T" in the kit. After explaining what my set-up was they referred me to Motorsportz.
  16. Motosportz CH Sponsor
    I have stock here I can measure.
    1.5 gallon is 13x9x5.5
    2.0 gallon is 13x9x7
    pictures of both tanks on the 1st page of this thread.
  17. Motosportz CH Sponsor
    I'm trying to help not be difficult. I dont have that model in from of me, if you say there is no low pressure line to T into it will not work. Thanks.
  18. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Have you had any experience trying to put one on a Gas Gas 2 stroke per chance? From looking at their website, tank #7 might be the closest match...?
  19. Motosportz CH Sponsor
    Not really but if you give me some dimensions where it will mount I can let you know what looks closest to working.
    K
    Phoenix likes this.
  20. jon6.0 Husqvarna
    Phoenix
    2011 TE449
    Can any of the larger tanks be fitted to the TE449?
